Inventor Forum
Query on STYLE and Standard Editor
3 REPLIES 3
WillieArolf
1289 Views, 3 Replies
Good day all,
1. How to make the STYLE and Standard Editor "NOT" Read Only. As a user, I do have the Administrator permission.
2. I have created a Style but then I do not want it anymore. How? Can I delete it.
Thanks & Regards,
Willie
Autodesk Inventor Professional 2019
Windows 7, 64-bit
3 REPLIES 3
Please check the copy & delete styles sections of the following wiki help for Inventor. This would help you to resolve your query.
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/2108-CAD_Mana2108/2119-Configur2119/2120-Style_l...
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
This post on our blogs could also give you some additional information of how the styles are managed in the latest version of Inventor:
http://beinginventive.typepad.com/being-inventive/2011/05/how-to-preserve-cached-styles-in-inventor-...
Daniela Koloszko
SBix26
in reply to: WillieArolf
Read-only status has nothing to do with your user account.  It is controlled by the project file (.ipj) in which you are working.  In the project editor, create a new project just for editing your style library, and right click on "Use Style Library = Read-Only" and change it to Read-Write.  Typically, you should use Read-Only for routine use so you or someone else doesn't accidentally mess up your library.
To delete a style from the library, you need to use the Style Library Manager utility (find it under your Start menu).  Use it carefully!
