Inventor General
Member
zackdarker
Message 1 of 7 (283 Views)
Pulling Hair Out!! UNITS
283 Views, 6 Replies
02-02-2013 10:51 AM
Newbie Alert !!!
Simply importing old (.dwg) files (drawn with autocad 2008) into inventor 2012
it then converts my units into mm for me ...handy... not they are already mm and it thinks they are inches
so e.g original drwaing is 50mm tall,  inventor then changes that to 1270mm
Please help driving me up the wall.  lol
I Installed inventor and config for its default unit to be in mm
so what am I doing wrong??
JDMather
Message 2 of 7 (276 Views)
Re: Pulling Hair Out!! UNITS
02-02-2013 11:32 AM in reply to: zackdarker
Attach original dwg file and the resulting ipt file here.
What I will immediately check is the -dwgunits of the original dwg file
and then
the Tools>Document Settings>Units of the ipt file
then
I will try bringing in the dwg into the ipt file myself and see what units the Wizzard detects.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
New Member
pmason48
Message 3 of 7 (265 Views)
02-02-2013 12:03 PM in reply to: zackdarker
My personal preference when converting is if I'm converting a dwg that was drawn in inches I select the ENGLISH TAB then STANDARD INCH IPT. I then go through the usual Manage tab, import select the file type on the first page then select the INCH option in units on the second page.
By doing this the only problem I now have is that I keep getting told that MDT needs to be installed for this operation, it has been since 2008. But that's Inventor for you!!!
Member
zackdarker
Message 4 of 7 (261 Views)
02-02-2013 12:11 PM in reply to: JDMather
Thanks JDMather
any help would be greatly appreciated
Member
zackdarker
Message 5 of 7 (244 Views)
02-02-2013 12:39 PM in reply to: zackdarker
Clearly Im not having a good day
lol
Member
zackdarker
Message 6 of 7 (238 Views)
02-02-2013 01:03 PM in reply to: zackdarker
Update :
In Auto Cad 2008 I
-dwgunits
3 (mm)
then enter enter enter confirm yes change scale units blah blah
and i configured inventor when installing to be set by default to work in mm and confirmed this
by document settings-units so
where am i going wrong???
JDMather
Message 7 of 7 (213 Views)
02-02-2013 06:57 PM in reply to: zackdarker
When I run -dwgunits on your dwg file it indicates it was done in inches.
When I Import the geometry and change the units from the detected units of Inches to the Intended units of mm and then reset the Tools>Document Settings>Units to mm in Inventor the dimensions read correct.
BTW - this appears to be a sheet metal flat pattern.
Flat patterns are almost never done correctly in AutoCAD.
Model in finished form in Inventor rather than folding this.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
