Inventor General
Distinguished Contributor
Infoseeker
Message 1 of 15 (278 Views)
Accepted Solution
Publishing ipart to Tube and Pipe - exporting iproperties?
278 Views, 14 Replies
05-18-2012 03:44 PM
I am trying to publish an ipart with different pipe profile diameters to T&P.
The problem I have is, I want for each profile in the ipart table have corresponding custom iproperty value assigned to it.
E.g.
When the ipart is published and I use it in an assembly:
I want to pick lets say 2" diameter of added profile, have T&P create the part and then I want my custom iproperty for this part to be 001.
If I pick 3" diameter I want the custom iproperty be 002.
Played around with authoring and publishing but so far no luck.
Distinguished Mentor
pcrawley
Message 2 of 15 (262 Views)
Re: Publishing ipart to Tube and Pipe - exporting iproperties?
05-19-2012 04:39 AM in reply to: Infoseeker
You might need to be a bit more specific about what you are trying to achieve. From your description it looks like you are creating item numbers. Generally, if you want to add a custom iProperty to an iPart, you add it in the "Other" tab of the iPart table editor. So every row of the table can have a different custom property.
Peter
Infoseeker
Message 3 of 15 (245 Views)
05-23-2012 01:41 PM in reply to: pcrawley
I tried to describe it as straight forward as possible.
Our part template has a custom iproperty added, lets say its "MANUFACTURER".
Every part we create has this iproperty - when we create parts lists, one of the columns in the parts lists is "MANUFACTURER".
Now, I create an ipart with lets say different PVC pipe profiles: 2", 2 1/2" and 3".
2" pipe is purchased from a manufacturer A.
2 1/2" from B,
3" from C.
I can add this info to my ipart creating custom column ("MANUFACTURER") in my ipart table.
When i publish the ipart to T&P, and then create a pipe using added info, I get 3 options to choose from, 2", 2 1/2", 3".
When I create a pipe using 2" profile, and I open this part, I want it to have an iproperty "MANUFACTURER". I also want this iproperty to have a value of A.
When i pick an option of 2 1/2" and open created part I want it to have "MANUFACTURER" iproperty to have a value of B.
And so on...
I can transfer this value when I create an ipart with one option in the table but not with more than one...
Infoseeker
Message 4 of 15 (235 Views)
05-24-2012 07:31 AM in reply to: Infoseeker
Anyone?
Infoseeker
Message 5 of 15 (222 Views)
Re: Publishing apart to Tube and Pipe - exporting properties?
05-25-2012 07:55 AM in reply to: Infoseeker
Probably I should be able to accomplish this with a simple ilogic code (which I will experiment with) but I hoped for a simple solution within "traditional" Inventor...
I am surprised it can't be done.
pcrawley
Message 6 of 15 (213 Views)
05-26-2012 12:44 AM in reply to: Infoseeker
No such word as "can't" with Inventor. If you use it, it just means you haven't tried hard enough :smileywink: I'm not infront of Inventor, so I'm doing this from memory: When you are editing the iPart, the last tab of the tab of iPart table table editor is called "Other". You can add your own property names in here and they appear as new columns in the table. Now you can add your own values to each member of the iPart. And not a line of iLogic code anywhere. Peter
Peter
Infoseeker
Message 7 of 15 (205 Views)
05-26-2012 12:22 PM in reply to: Infoseeker
Lol, you sound very optimistic about sky being the limit for Inventor :smileywink:.
I will check it out on Monday.
Before I added new column to the ipart table, entered different value for each ipart option in the table, the problem is to export these values when publishing the part to T&P and have different iproperty value appear when you populate a particular option of the ipart.
pcrawley
Message 8 of 15 (203 Views)
05-26-2012 12:30 PM in reply to: Infoseeker
Re the publishing - I think you have to make the new column a "Key" by right-clicking the column name.  When publishing, it then prompts you to include "key" columns.
Peter
Infoseeker
Message 9 of 15 (195 Views)
05-28-2012 07:22 AM in reply to: pcrawley
Well...
Went thru your post again and this is excacly what I did last time.
Maybe I am doing soemthing wrong but when i use published profile, create new part with it, it does not have custom iproperties, eventhou they were in the ipart table.
Maybe it has something to do with attached pop up message...
Infoseeker
Message 10 of 15 (181 Views)
05-29-2012 07:23 AM in reply to: Infoseeker
So...
Back to ilogic?
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
