I published our Dirt Seal I-Part from our Inventor Library to the Content Center.
Then I renamed the Dirt Seal File So Inventor can not find Dirt Seal.
I open an assembly that has a dirt seal part and it asked me to resolve the link. I go to the Content Center, I find the Dirt Seal Folder. I don’t see any parts in the folder. I don’t see any file named Dirt Seal?
So I canceled that, opened a new iam and opened added a new part from content center. I added the same seal that was in the original assembly, saved. Reopened original assembly try to resolve the link to the dirt seal,
I go to the content center, to the dirt seal folder, the seal file is there now I select it but it will not let me resolve the link on the at file.
Any Ideas how to do this?
Solved by cbenner. Go to Solution.
I'm not sure why you were not seeing your newly published part in the CC, but now that it is showing... instead of resolving the link, try accepting the assembly with the link broken. Then once it's open do a "Replace from Content Center" on the dirt seal. We've had to do this with a lot of our old piping assemblies that were done pre Content Center.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
