How do you turn off the default check for "Propigate to parent view" when creating a breal in a drawing view. I have never had the need to use this option yet it is checked by defalt.
Kevin,
The fact that no one has responded to this tells me a few things. Either there is no answer, it can't be done or it takes iLogic to facilitate this. I know my setting is defaulted to being checked. After numerous google searches and combing the applications options I came up with nothing that seems to change this default setting.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I think this is really a "red herring". The sketch must propagate back to the base view in order for the Break to take place. If it didn't you wouldn't end up with a break but some sketch geometry on the base view.
If you are talking about the fact that when this is checked the break shows up in the parent view as well, the software is doing exactly what you asked it to do. That is what that means when you check that box. If you don't want those results then uncheck the box. Seems to me like that would be the simple solution.
Unless there is more to your point.
I don't believe you can, this would then not be a break view. I think some programmer just used existing code for the box and hard coded the "Check" in the box.
Not all the code for Inventor is written at the same location. This section of code could have been written way back in one of the first releases and has never needed updating.
Ok, now that this is as clear as mud!!
I would go back to my original posting on when I first responded to this same question.
