Hello All,
Quick question on driver updates. Do I still need to update the "Graphics Databases" XML files when I update the graphics drivers on an Inventor and/or AutoCAD 2013 or 2014 workstation? If so, where can I find the latest versions of the XML files?
It used to be easy to get the databases, they where provided with the drivers on the Autodesk Certified Hardware website. Now, I can't find them anywhere.
Thanks!
Solved by blair. Go to Solution.
With the move about 5-6 releases ago from OpenGL to D3D all that is required is Microsoft Certified drivers for Inventor. ADSK has quite posting current graphics hardware lists.
Not sure about Autocad, you should try posting Autocad related questions on the Autocad forum.
