Inventor General
New Member
Holmskov
Message 1 of 2 (189 Views)
Projection of a Break Out View??
189 Views, 1 Replies
05-15-2012 10:58 PM
Hi
I have a problem. I have a cylindrical shape, which I want to cut in an angle of 120 degrees, through the entire profile, in the idw. I did this with a break out view, but the problems is, when I then want to project the view, so I can see the inside of the cylinder, it projects the original, full shape, instead of the break-out shape.
Only if I drag the projection to the side, so it creates an isometric view, the correct shape is shown.
Any ideas on how to do this? I have attached a little step-by-step picture, of a dummy-model, to illustrate the issue.
Best regards
Holmskov
trumpy81
Message 2 of 2 (186 Views)
Re: Projection of a Break Out View??
05-16-2012 12:05 AM in reply to: Holmskov
The only way I can think of is to create a second dummy part with the breakout already modelled on it, then place that part and project it to your hearts content ... lol
It might not be the most elegant solution but it should work if you can't find any other way.
Regards
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
