The file got stuck in my outbox for some reason.
It's 2.5 MB zipped file. I get a message in Outlook Express that file must
be no larger than about 1.5 MB (see below).
Outlook Express could not post your message. Subject 'Projected geometry
goes awry ', Account: 'discussion.AutoDesk.com', Server:
'discussion.AutoDesk.com', Protocol: NNTP, Server Response: '441 Articles
may not be larger than 1572864 bytes', Port: 119, Secure(SSL): No, Server
Error: 441, Error Number: 0x800CCCA9
Is this a new restriction on the CF NG server?
Strange since there 16MB files posted in CF.
Gary
gcross@crossdesign.com
"Hugh Henderson (Autodesk)" wrote in
message news:406c6351$1_3@newsprd01...
> Gary,
> For some reason, I don't see the dataset in CF. Would you mind checking
> to see that it is there?
> Thanks,
> "Gary Cross" wrote in message
> news:406c5c1a_3@newsprd01...
> > When changing an extrusion a little deeper (a shelled pan shape),
another
> > extruded feature (inside lip based on an offset of projected geometry)
> > looses it's shape & becomes something very different (bad).
> > See files in CF
> > I assume feature adaptivity here would be the answer but how do you
> > establish adaptivity to projected geometry projected from the edges?
> > Is this correct behavior otherwise?
> > Gary
