Mike,
Do your BR2 model files "live" on the server or locally?
The idea behind the IPJ path in App Options is to assign a (local) place
for the shortcuts to "live".
The actual IPJ should exist with the model files (usually on a server)
with the "browse" button in the Open Dialog (projects icon) used to find
the actual IPJ. IV automatically creates a shortcut in the IPJ path
called out in App Options.
If IV is allowed to create and place the shortcut properly (as designed)
it should stick and be available in further sessions.
I *believe* that if you use Explorer to find a IPJ and double click the
IPJ to start IV, IV will fire with that project active, but it will NOT
remember (or place a shortcut) where you "found" the IPJ in later
sessions.
QBZ
"mpower" wrote in message
news:B8D57E6053D39329B2735E692B956A64@in.WebX.maYIadrTaRb...
> I have a made a specific project file for a project I'm working on
called
> BR2.ipj. The workspace is on my C: drive and the project file is
there too.
> Inventor is set to look for project files in a network folder called
G:\Path
> Files and I put a shortcut of the BR2.ipj in the that folder.
Everything
> worked fine. When I wanted to work on the BR2 project, I found it in
the
> project window of IV and selected it. When I was done with this
project for
> the day, I went back and selected a different project to work on and
> continued with my day. The next day, I went to work on BR2 again, and
the
> project was not listed in the dialog box. I checked the G:\Path Files
> folder and the shortcut was gone. Okay, I made a new shortcut and put
it
> back in G:\Path Files and everything was fine. Next day, same thing.
The
> shortcut was gone again! Why does this happen?
> Mike
