One of our employees is having an issue where his project file keeps reverting back to a default setup and his changes are being lost. Is there anyway to prevent this from happening?
Solved by Cadmanto. Go to Solution.
Is inventor crashing..
I believe it needs to "close" properly for certain changes to stick.
Of course what version are you running? Are you up to date on hotfixes/service packs?
Under "Application Options" try selecting this.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
