Anyone know how to set up the Productivity commands in an assembly so that the Add Part/Assembly commands use our default custom templates we created. Application options are set up to the location of our standard templates as well as the project file. Yet when we use the Add Part/Assembly command from the productivity panel in an assembly it does not carry over our default settings.
Solved by swalton. Go to Solution.
Solved by jtylerbc. Go to Solution.
What version of Inventor? Are you talking about the Create In Place Component? There is a pull down in the dialog that allows you to select the template, which should default to the paths you have set up. Is this what you want to do?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
We use Autodesk Professional 2014. I have included a screen shot of the commands that I am trying to use (Add Part/Assembly command) located on the Productivity Tab of the Assemble ribbon
As best I can tell, at least in 2013, these commands use Standard.ipt and Standard.iam from the default templates folder. I just tested it, and it does carry over properties and other information that we have in those templates. Are you saying that yours doesn't pull from the Standard templates, or that you're trying to get it to pull from a template other than Standard?
I have never changed any settings to enable this - in fact, before this test I had never used these commands at all.
I would try renameing the templates. I bet that the productivity shortcuts work just like the new file dropdown shortcuts in the ribbon bar.
Name the templates that shipped with IV something like "standard-as-shipped.iam".
Then rename your custom templates to "standard.iam" .
Steve Walton
Yes, we have renamed our custom templates from the standard names that came with inventor and they are located in a completely different folder. So it sounds that if we rename our custom templates back to the standard names that this function will work. Thanks.
