Inventor General
New Member
zreed042
Message 1 of 4 (375 Views)
Problems with threading
375 Views, 3 Replies
01-12-2012 11:40 AM
Howdy fellas. I'm designing a flashhider that fits on an airsoft gun using AutoCad Inventor and trying to print it using the 3D printing service, Shapeways. The threads on the gun are M14-1 and when I use the thread feature in Inventor all it puts on the part is a 2D texture. When I upload the model to any other software (Meshlab for example) the threads are gone. So, I downloaded a pllugin that models the threads in 3D. This fixed the problem in part, but when I upload the model to shapeways (in an .stl format) I get some weirdness.
Here's the flash hider:
And here's what shapeways thinks I upload:
It somehow fills in the hole that I tapped and threaded. Is there any way to fix this?
mcgyvr
Message 2 of 4 (365 Views)
Re: Problems with threading
01-12-2012 11:55 AM in reply to: zreed042
If you increase the quality of the stl file during export does it fix the problem?  When you do a save copy as to save to stl hit the options button before you save and mess with those settings..
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
New Member
zreed042
Message 3 of 4 (362 Views)
01-12-2012 12:02 PM in reply to: mcgyvr
You know what, that totally fixed the problem! (I also drew the thread manually)
JDMather
Message 4 of 4 (352 Views)
01-12-2012 12:36 PM in reply to: zreed042
Also check the units when creating the stl as Inventor defaults to CM rather than document units.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
