Inventor General
*Corbin, Brian
Message 11 of 14 (40 Views)
Re:
11-21-2002 10:30 AM in reply to: *Corbin, Brian
Jeff,
I have been told that dialog should be edit to be a little more descriptive
in a future release. Now that I have it working I guess I have to look at
how I am gonna use it. It would seem the control click thingy sounds like it
would be ok. So let me get that clear..
If ECPG is off and you project a face you get pink edges which are not
associative?
IF ECPG is off and you ctrl+slect you get associative edges?
Confused, you betcha
Brian
"Jeff Howard" wrote in message
news:33E7CF693790A912E4528F909F96600C@in.WebX.maYIadrTaRb...
> I wonder if it would be possible to have an error message indicate what
the
> problem is? This would have driven me nuts, too.
> On a side note, I noticed that even though I have [enable cross part assoc
> proj's] off, the faces of other parts in the assembly were selectable for
> projection, which shouldn't be.
> Brian, I don't know if it's any help for you (and you are probably aware
of
> it); I think it's a consensus that it's best to keep the functionality
turned
> off and use to make the projections associative when
desired.
> Jeff
> "Brian Corbin" wrote in message
> news:79FE28CA227709A5D193E226F8803D90@in.WebX.maYIadrTaRb...
> Got it Thanks Chuck.....
> Brian,
> Yes, we did get a chance to look into this. The problem is that the part
> you are using is "adaptive" in some other assembly.........
*Howard, Jeff
Message 12 of 14 (40 Views)
Re:
11-21-2002 01:01 PM in reply to: *Corbin, Brian
Confused... me, too. There have been some changes with 6 and
I didn't really have a handle on cross part projection in 5, but if I
understand correctly...
With ECPG off, you cannot even select a face of another part, but only edges.
{I found your assembly odd in that respect and can only suspect it is a bug,
along with the cross part projection of silhouette edges coming up black
instead of pink (they are not associative), but let's not worry about that as
it will only confuse matters.} The projected entities should be magenta /
pink, are not associative and create no "Reference" attached to the sketch.
CTRL+Select will allow the selection of faces or edges on other parts and they
should project as black entities, be associative and create a "Reference"
nested under the sketch (the same behavior that should occur if ECPG is on).
Also, keep in mind that there are limitations with regard to the relationship
of the part being edited to the assembly. I don't remember the specifics, but
I that it's not possible to do an associative projection from a part
that is in a higher assembly or in parallel assemblies. I think of the
assembly as a tree with the trunk being the top level assembly and forking
branches being successively deeper layers of sub assemblies. Given that, it
should be possible to project from an entity that is in the same branch or
closer to a limb tip, but not the other way around. Again, I'm not that
familiar with the functionality, so may be incorrect.
Have a good one,
Jeff
news:95E775F374961E75E87A326296612F12@in.WebX.maYIadrTaRb...
Jeff,
associative?
Brian
*Yeandle, Laurence
Message 13 of 14 (40 Views)
Re:
11-21-2002 04:47 PM in reply to: *Corbin, Brian
Jeff, I think the posts are screwed at my end anyway, Projected faces are
now Black it appears in 6.0 Project Cut Faces are Pink still. Chuck said
go to tools document settings modelling tab Adaptivity used in Assembly. Did
you get that bit.
Laurence,
Power is nothing without Control
news:83677F9FAA9E63904FDAA6F72AE2CB99@in.WebX.maYIadrTaRb...
edges.
bug,
as
sketch.
they
on).
relationship
but
part
it
> Have a good one,
> Jeff
> Jeff,
descriptive
it
> associative?
> Brian
*Howard, Jeff
Message 14 of 14 (40 Views)
Re:
11-21-2002 07:53 PM in reply to: *Corbin, Brian
Uh huh 8~)
"Laurence Yeandle" wrote in message
news:60AA4DA06DC2E6899F6DDF120AF5C0DB@in.WebX.maYIadrTaRb...
Did you get that bit.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
