Please, when I try to create a Thread on a Hole in any project, thats isn´t possible.
could anyone help me???
My Invertor version: 2013!
Did this work before?
Do you have MS Excel installed on this machine?
The CADWhisperer YouTube Channel
This problem has come up here many times in the past.
I did not pay atttention to the solution because I did not experience this problem.
A search here might turn up possible solutions.
You might also try a Repair Install (with UAC at lowest setting).
If nothing else works -
Clean uninstall.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Clean Install
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17955581&linkID=9240617
Have you
1) Run excel since installing IV
2) have you run any software to clean the registry?
I have some time had this happen, now and again, where for some reason Inventor dose not see the thread.exl file usually shutting down Iv and restarting seems to fix it,
