Hi everyone, I work at a small engineering firm and am having some problems on a project I am working on. I am making an as-built of a wash ramp for half ton trucks and I cannot get the length of the ramp in the model to match the length of the existing ramp. The ramp is made of 6"x4"x1/4" HSS and it is mitered at the one end where the top and bottom HSS meet (where the truck begins up the ramp). I am using Inventor 2014 with a skeleton (sketch) and frame generator. The total length I need is 474 5/8" but every time I adjust the total length in the sketch the model will either not change at all or jump from 472.291" to 476.524". If anyone can help me out I would appreciate it. I've already asked around my office and nobody has any ideas.
Welcome aboard.
Something like this is very hard to guess at without seeing the files... would it be possible to post your frame assembly (with all of the parts) so we can attempt to diagnose?
Hint: Roll up the EOP to the top and do a Pack and Go to reduce the size and assure all the parts are there.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Welcome to the forum.
I agree with Chris that this is hard to diagnose without files or images.
But I will say this. I know when you use a skeleton file with specific line lengths, if you do not miter
or trim your parts what shows up in the BOM should be that exact length. But, when the miters are used,
that does change things. I have always gone with wht ever length is showing up in the BOM for ordering
purposes. Not sure if this helps you, but it is my two cents.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
@Anonymous wrote:Hi everyone, I work at a small engineering firm and am having some problems on a project I am working on. I am making an as-built of a wash ramp for half ton trucks and I cannot get the length of the ramp in the model to match the length of the existing ramp. The ramp is made of 6"x4"x1/4" HSS and it is mitered at the one end where the top and bottom HSS meet (where the truck begins up the ramp). I am using Inventor 2014 with a skeleton (sketch) and frame generator. The total length I need is 474 5/8" but every time I adjust the total length in the sketch the model will either not change at all or jump from 472.291" to 476.524". If anyone can help me out I would appreciate it. I've already asked around my office and nobody has any ideas.
Let me ask this,.. have you tried "Rebuild All" on the Manage tab? Sometimes it may be that simple.
Chris Benner
I agree that its difficult to understand without the file. Unfortunately I talked to my boss and he doesn't like the idea of our "property" being put up on forums. Sorry guys. He suggested making an extrusion on the assembly to cut it back to the correct length but then it won't match the existing ramp. But if he's ok with it thats what I may end up doing. I appreciate the quick replies.
You could also try to re-create the issue on a dummy assembly, and then post that here so it's non-proprietary. Or if your boss would be ok with it, you could email one of us the files to look at privately. I understand that though, I would have a hard time posting files here too since everything we do is proprietary.
Chris Benner
I would suggest there's some sort of snap turned on but the distance between the two points (4.233") is really odd!
Since you can't post your files - see if you can reproduce the behavior.
Sounds to me like you only need one line in the skeleton and one frame member to test.
Can you reproduce?
