Hi!..I'm a new user of the Autodesk Inventor Professional 2013 English..I have updated the it to Autodesk Inventor Professional 2013 SP2..
I have encountered a problem in saving Inventor 2D (idw) files to DWG.. The warning; "Problems encountered while saving the document" pops every time I try to Export the 2D files to DWG format.. I have no idea why this problem is occuring because i have set the application options; drawing tab to inventor drawing (dwg) and the inventor DWG file version to Autocad 2000..
Hope you can help me on this guys..
cats_eye
I suggest you try over at the Inventor forum... The same for you're other 2 posts in this newsgroup
http://forums.autodesk.com/t5/Inventor/ct-p/70
Mark
There are a couple more SP's and Updates for your product. I don't think these will help but are worth installing. Try logging in as a different "User", one with Administrative rights and see if this solves your problem. Also check that you have "Read Rights" to the directory that you are trying to save to.
