Please see picture attached, I am unable to construct or place nuts to fix this threaded steel rod to a cylindrical tube
Please help!
Hi Steve,
Can give more details please. Why not create the connection? Any error message?
I have tried the coincentric method and it reconises the end of the shaft, the hole, but will not recognise the outer surface of the cylinder as a termination point. It will recognise the end of the shaft but this means it is not tight against the surface
Workpoint
Attach your assembly here.
This what you want? Not sure what your intent is for the internal nut, assuming this is what your after.
NOTE: the M30-3.5 in CC has the wrong thread info. I inserted these as custom and fixed the thread.
