Our designers state that when they create a drawing with Inventor and save it locally, if they make changes to it after the save and want to save again they can only do a save as. The only way out of this is if they check the drawing in and then check it out again. Is there a setting error, has anyone experienced this before.
Thank you
Hi and welcome,
I think we need more information about your setup. What versions of software are you using, and is this a Vault environment? Are the drawings that are being edited checked into Vault.... and do your users first do Get Revision on them? Is this a network environment?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Welcome to the forum.
Sounds like when they are checking the files into the vault they are not retaining ownership. So when they check in the files make sure this is checked and they wont have this issue.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
