Inventor Forum
Problem with flat pattern size
1 REPLY 1
chad38
309 Views, 1 Reply
I'm having a problem with a part. I'm aiming for a particular overall cut size, and figured i would adjust my kfactor to hit the overall length needed on this particular part. Problem is, it seems no matter what I do, I keep getting 42.3". I've even taken my Kfactor all the way up to .9 with no change. I've tried using my bend table with no change to the flat size. I adjusted my bend radius, no change whatsoever. I have included the part in question. I'm aiming for the part to be 45.760x 42.380. It currently is and keeps being 45.760x 42.3
Any idea why this is happening?
HP Z420 Workstation
Intel Xeon CPU E5-1603 0 @ 2.80 GHz 2.80 GHz
12.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Solid Edge ST9 MP1
Inventor Professional 2015
Autocad 2015
SolidWorks 2015
Tags (2)
1 REPLY 1
-niels-
in reply to: chad38
Your "sheet metal defaults" is set to one type, but "contour flange 1" is set to it's own bendtable on the "unfold options" tab.
Set it back to the default and you should start seeing differences.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
