I am just using this slide as an example.
When I try to sweep along the whole path it gives me an error message that my path is discontinuous.
When making the second arc in the curve I tryed snapping it to the endpoint of the first curve and also tried making a point where the two lines would meet. Niether of these worked.
I know I don't have the right constraint but would like to know what I am missing.
I am also having problems getting any shapes that I make out of of two or more arcs/lines to offset or extrude.
I included an example of the shape that I am trying to offest. It only let's me offset one segment. Also will not let me extrude the shape after I finish the sketch.
It is probably something in my settings because I can go to the CADstation downstairs and do both of these drawings no problem.
I'm using Inventor 2014 (student).
Kyle
I figured it out,
I didn't have the "all" checkbox ticked under "Scope of constraint inference" in the constraint options.
This helped with both problems.
