Inventor Forum
Problem with dimensioning in drawing
5 REPLIES 5
356 Views, 5 Replies
I have a problem in one of my drawings.
When i try to dimension from the bottom line to center of te circle, the dimension is placed wrong. (see image) selection of geometry is in blue
i have 4 plates like this, and i used replace reference model to create the other three. But also in the original file the problem occur (the files are in attachment)
5 REPLIES 5
-niels-
I had no problems placing the dimension in IV2014, but from the file i saw that you are on 2011 SP2.
Is your inventor entirely up to date?
I saw there are quite a lot of hotfixes, maybe there is a solution for this...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
in reply to: -niels-
Everything is up2date...
-niels-
Then i don't know what might help, maybe someone with the same version of IV might know.
Otherwise, if possible, try contacting Autodesk support if this is reproduceable.
Veel succes.
Niels van der Veer
The Netherlands
GSE_Dan_A
All works well on my end too (IV 2014).
GSE Consultants Inc.
Windsor, ON. Canada
BLHDrafting
Dimensions fine in 2013 also.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
