I'm in grade 12 and i had to create a vending machine and i did. But the problem is when i use the drawing feature in inventor it isnt showing the whole vending machine only parts of it...
look:
how do i get the whole machine to show??
Solved by rhasell. Go to Solution.
Show screen shot of the part or assembly ipt/iam or attach the files here.
Hi
I have not analysed everything, but to fix your immediate issue.
Expand the tree, find the solid body listed under "Surface Bodies", RMB and enable visibilty.
The reason this happened was the "Delete Face" feature. This converted the solid body into a surface Body.
Try use the Shell feature instead.
