Dave,
If you are still having a hard time getting Inventor Installed Please
contact me. I will be available after 1:00pm Pacific time.
David
david.w.harris@autodesk.com
________________________________________
Technical Liaison - Rapid Response Team
Autodesk Inventor®
Manufacturing Solutions Division
Autodesk, Inc.
7995 SW Mohawk
SouthCenter, Bldg A
Tualatin, OR 97062
Tel: (503) 612-2463
Fax: (503) 692-1630
This e-mail transmission is intended only for the use of the individual(s)
named above and may contain information that is confidential. If you are not
the intended recipient, you are hereby notified that any disclosure,
copying, distribution, or use of the information contained in this
transmission is strictly prohibited.
"Dave Silverberg" wrote in message
news:4817237@discussion.autodesk.com...
>I find nothing in the temp files that has anything to do with inventor
> Can I ask you to please send me your phone number to
> dave@lektralabs.com so that maybe we can figure this out. I would like
> to start using IV 10 and I can't without these parts libraries.
> Thanks
> Dave
> "Jeff Pek (Autodesk)" wrote in message
> news:4816967@discussion.autodesk.com...
>> The installation logs are placed into your TEMP directory. You can
>> usually see logs such as AIS10Install.log, MSDE_CC_Setup.log, in there.
>> The easiest way to get to it from Windows Explorer is to type in %TEMP%
>> in the address bar and hit enter (or Go).
>> jeff
>> Dave Silverberg wrote:
>>> I just followed all the inputs that it asked for as it installed itself.
>>> How do I reach the installation logs.
>>> While I am not in anyway a computer wiz, I use inventor to design
>>> equipment with hundreds of parts and am generally very happy with it's
>>> workings.
>>> news:4816978@discussion.autodesk.com...
>>>>To get to the bottom of what may be going on, we'd really need to take
>>>>a look at the installation logs. 1.5G seems like a pretty reasonable
>>>>configuration, so should be a good start, at least. It certainly is
>>>>plenty of RAM to get through an installation!
>>>>Jeff
>>>>>There really are no more details. I did not try to use IV10 yet.
>>>>>When
>>>>>I
>>>>>saw I did not have these contents, I decided to stick with nine until I
>>>>>find
>>>>>the solution. The Ikon is not in the tool browser at all.
>>>>> I am running a P4-3g with 1.5 gig of Ram. Do you think I need
>>>>> more
>>>>>ram
>>>>>in general for efficient running with IV 10.
>>>>> Thanks
>>>>>news:4816316@discussion.autodesk.com...
>>>>>>If you can provide more details of the failure symptoms, we may be
>>>>>>able
>>>>>>to help. Other posts might also be useful if you search for "install"
>>>>>>in
>>>>>>the NG.
>>>>>>Note that you should be careful of which logs you post, as some
>>>>>>actually
>>>>>>contain a license number (!).
>>>>>>Jeff
>>>>>>>My Content Center did not install. I left User can make changes to
>>>>>>>the
>>>>>>>Content Center libraries and publish checked. Must I try an
>>>>>>>installation
>>>>>>>from scratch or might there be a quicker fix?
