Inventor Forum
Problem while exporting an Inventor assembly file into .IGES or .STEP
5 REPLIES 5
KulasekaranK
5045 Views, 5 Replies
Dear all,.
I am using Autodesk inventor professional suite 2012.
I am working in a Chain Manufacturing company in India.
Generally our customers asks the 3D model of a particular component to attach in to their main assembly, so I will convert the component by using 'Export' or 'Save as' to .IGES or .STEP.
But this time our customer asks the full chain assembly to install into their machine and run.
So they are asking the assembly file in ".IGES or .STEP"
I converted the chain assembly like always I do, but after converting the 'constrains are gone' in .IGES & STEP.
If I move or float the chain assembly in all sub assemblies & components coming separately,.
So they couldn't attach the assembly in to their machine assembly,.
I attached the picture here for better understand,.
Please advise me,.
Thanking you.
5 REPLIES 5
JDMather
in reply to: KulasekaranK
Start a new part file.
Go to Manage>Derive and derive the assembly into a single part file.
Now Save As type STEP or IGES.
It sounds like the customer does not understand how to use sub-assemblies or that neutral format files (STEP or IGES) do not preserve assembly constraints.  I recommend that you refer the customer to this discussion.
KulasekaranK
in reply to: JDMather
Dear sir,
Thank you very much for the answer,.
Please let me know, is there any other format that retain the constrains, even if we convert?
The ultimate aim is, they want to use the chain in an assembly with drive and driven sprockets and neet to run.
And also why Autodesk doesn't make this feature (retaining constrains)?
Thanking you.
CCarreiras
Hi!
No, when you export to other formats, you lose the assembly constrains, and you lose also other features like the treads information.Other properties are maintained like color, Material, position...
Tip: When you import the assembly from step or other format, "Grounded" all parts to maitain the correct position.
Regards.
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
CCarreiras
JDMather
It is not easy to do this.
LOONYLEN
You must first "Shrinkwrap" your model then, "Save As" .stp file.
The file size will grow but you will realize the desired result.
-Len
Senior Designer/Cad Administrator
Inventor 2012, w/SP2
Vault Collaboration 2012
Dell Precision T3500, Intel Xeon CPU
W3680 @3.33GHz, 16.0 GB of RAM
Microsoft Windows 7 Pro, 64 Bit Edition
Version 2009, w/SP1
