I want to create a solid using VB and loft definition.
I creat each time different planes that have a constant distance in x dimension and a steady rotation each time φ (deg).
On each each plane i sketch the same profile and that is happened for 360 deg.
The problem is that Loft is not made because a line of the profile must follow a line tragectory and all other points must follow a circular tragectory. Also, there is a problem from 180 deg to 360 because there is intersection of profiles.
The result must be a solid similar to snail shell but all the same solid, as a cylindar whith a half sphere in the bottom.
Can somebody help me? please
It is too important for my work.
Thank you!
Attach the file here please.
Thank you very much for your imediate response!
My code is:
Public Sub gg()
Call CreateDir
Call SetDir
Dim fz, x, Diam, deg, stang, tz, txy As Double
Diam = 20 / 10
fz = 0.6 / 10
tz = 0.6 / 10
txy = 0.6 / 10
deg = 10
stang = 0 'start angle
h = 15 / 10
x = deg * fz / 360
Call BEM(Diam, x, deg, stang, h)
MsgBox ("Done !!!")
End Sub
Public Function SetDir() As String
SetDir = "C:\TasksDVAK\" & Year(Now)
End Function
Public Function CreateDir() As String
Dim SetDir As String
End Function
Public Sub BEM(Diam, x, deg, stang, h)
Dim oProfile As Profile
Dim oSections As ObjectCollection
Dim oPartDoc1 As PartDocument
Set oPartDoc1 = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
Dim oPartCompDef As PartComponentDefinition
Set oPartCompDef = oPartDoc1.ComponentDefinition
Dim oTrans As TransientGeometry
Set oTrans = ThisApplication.TransientGeometry
Set oSections = ThisApplication.TransientObjects.CreateObjectCollection
Dim oPnt As Point
Set oPnt = oTrans.CreatePoint(0, 0, 0)
Dim oWorkPoint1 As WorkPoint
Set oWorkPoint1 = oPartCompDef.WorkPoints.AddFixed(oPnt, False)
Dim oWorkPoint2 As WorkPoint
Set oPnt = oTrans.CreatePoint(0, 1, 0)
Set oWorkPoint2 = oPartCompDef.WorkPoints.AddFixed(oPnt, False)
Dim oWorkAxis As WorkAxis
Set oWorkAxis = oPartCompDef.WorkAxes.AddByTwoPoints(oWorkPoint1, oWorkPoint2, False)
Dim oWorkPlane As WorkPlane
Set oWorkPlane = oPartCompDef.WorkPlanes.AddByLinePlaneAndAngle _
(oWorkAxis, oPartCompDef.WorkPlanes.Item("YZ Plane"), 180 * 4 * Atn(1) / 180, False)
oWorkPlane.Name = "MyWorkPlane"
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc1.ComponentDefinition
Dim oSketch As PlanarSketch
Set oSketch = oCompDef.Sketches.Add(oWorkPlane)
Dim oTransGeom As TransientGeometry
Set oTransGeom = ThisApplication.TransientGeometry
For i = 0 To 360 / deg
Set oPnt = oTrans.CreatePoint(x * i, 0, 0)
Set oPnt = oTrans.CreatePoint(x * i, 0, 1)
(oWorkAxis, oPartCompDef.WorkPlanes.Item("MyWorkPlane"), (90 - stang - i * deg) * 4 * Atn(1) / 180, False)
Dim R, Rz, Rr, ar As Double
R = Diam / 2
Rz = Diam / 2
Rr = 0
Dim Mr, Mz, Nr, Nz As Double
Nz = Diam / 2
Nr = Diam / 2
Dim oLines(2 To 4) As SketchLine
Dim oArc(1 To 2) As SketchArc
Set oArc(1) = oSketch.SketchArcs.AddByCenterStartEndPoint(oTransGeom.CreatePoint2d(Rz, 0), oTransGeom.CreatePoint2d(0, 0), _
oTransGeom.CreatePoint2d(Nz, Nr), False)
Set oLines(2) = oSketch.SketchLines.AddByTwoPoints(oArc(1).StartSketchPoint, _
oTransGeom.CreatePoint2d(h, Nr))
Set oLines(3) = oSketch.SketchLines.AddByTwoPoints(oLines(2).EndSketchPoint, _
oTransGeom.CreatePoint2d(h, 0))
Set oLines(4) = oSketch.SketchLines.AddByTwoPoints(oLines(3).EndSketchPoint, _
oArc(1).EndSketchPoint)
Set oProfile = oSketch.Profiles.AddForSolid
Call oSections.Add(oProfile)
Next i
Dim oLoftDefinition As LoftDefinition
Set oLoftDefinition = oPartCompDef.Features.LoftFeatures.CreateLoftDefinition(oSections, kJoinOperation)
Dim oLof As LoftFeature
Set oLof = oPartCompDef.Features.LoftFeatures.Add(oLoftDefinition)
Call oPartDoc1.SaveAs(SetDir() & "Trajectory" & ".ipt", False)
oPartDoc1.Close
End Sub
