Inventor Forum
Problem mit Gewinde
6 REPLIES 6
rautenberg
2229 Views, 6 Replies
Problem mit Gewinde
Hallo,
ich bekomme die Fehlermeldung: Keine zylindrischen oder konischen Flächen für Gewinde gefunden.
siehe Anhang
Können Sie mir da weiterhelfen?
Danke
MfG
Michael Rosolski
6 REPLIES 6
MariaManuela
in reply to: rautenberg
Hi Michael Rosolski,
Sorry but i dont speck german.
I realize that the message appears because you tried to apply a thread on a flat face.
The Thread = Gewinde function works only on cylindrical faces.
Below the message in the English edition.
Asidek Consultant Specialist
www.asidek.es
rautenberg
sorry, that was a fault of mine. I now have a screenshot of the problem shows appended correctly.
Best regards
M. Rosolski
MariaManuela
Hi again,
One of Inventor System Requirements Microsoft® Excel 2003 through 2010 for iFeatures, iParts, iAssemblies, thread customization, and spreadsheet-driven designs
You confirm that? Check your "Excel" on the machines first.
In the Design Data folder
C:\Users\Public\Documents\Autodesk\Inventor 2012\Design Data....you see a Thread.xls file?
Confirm the path in Inventor Application Options
www.asidek.es
rautenberg
in reply to: MariaManuela
hello,
excel is running on this pc and i can access the Design Data folder. see srceenshot
there must be another problem, or?
MariaManuela
rautenberg
danke für die hilfe!
mfg
Michael Rosolski
