Hi all,
I want to use loft feature between two non-parallel sketches. I am not sure about problem in loft creation. I have attached part model with this message. Can anyone help me to overcome this problem ? Sketch 3 is upper profile, 3D Sketch 1 is lower profile and 3D sketch is rail profile.
Look forward to hear back from you guys..
Cheers,
Jagan
Solved by CCarreiras. Go to Solution.
Hi!
Somehow, your 3D sketch is inside the solid and that causes one error. Due to a litle deformation in the surface patch, i think that occurs in the cusp of the solid.
So, what i´ve made was, built a frontier using the 3d bondaries with patch tool.
This frontier is in some point a litle inside of the solid, so i extend it (any value, doesnt matter)
Then use the split solit to cut the portion i don't need, in that case the top portion, and that's it!!!
Take a look at the attached file.
I think you made all good, but sometimes software has these issues.... the important is to know several ways to achieve the same goal... one of them will work.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
Hi CarlosC,
Thank you so much for your help and time. Yes, i saw the model and top portion is removed. Now, i got another problem in this model. I want to do below steps
1. Select new sketch on the cut surface
2. Project the geometry of outer boundary
3. offset the projected geometry inwards for 7000 m
4. Later, i will create 3D sketch on another plane below the surface.
5. Now, use loft cut to remove the material inwards.
make sense ? Finally, it will look like a bathtub or pond. Now, i have tried to select the cut surface but doesn't work. It selects the extend feature. Even, i tried to create plane of surface using 3 points creation. But, it doesn't work.
Could you please help me ? If so, i would be grateful to you.
Cheers,
Jagan
Hi!
First you cant do a sketch in the surface just because it's not a plane surface, it's kind of a wave, you can only 2D sketch in plane surfaces.
Question: The first objecctive was crate a plane surface?!
Second, why you made the first extrusion, to cut again after?, why don't you sketched the rigth profile in the begining? (But that's ok now... the question is... was a waste of time in my opinion)
Third: what is your goal?, what you want to achieve. I can't help you if i dont understand where you can go.
Hi CarlosC,
Thanks for your reply. Yes, i understood that sketch can be done on planar surface. However, i have tried to create 3D sketch to get the outer boundary. Forget the offset inwards 7000 mm. Please see the attached file. I want to create the cut loft between 3D sketch 3 and 3D Sketch 5 with rail from 3D sketch 6.
I thought of doing this model as mold design concept. That's why, i have created block and started removing the material from the block or box based on requirements.
Please see the attached file and let me know your feedback.
Thanks again for your time and help
Cheers,
Jagan
Hi!
i think i finally understand what you need. We have to approach that in a different way. Let's work with surfaces to achieve the final solid, because this last 3d sketch is above the first patch tool in some parts (in the left side).
I'm sorry but i had to delete the 3D sketch (the last one).
Can you build it again? don't worry, we are near the end.
Hi CarlosC,
Thanks for your help. I have created 3D sketch as per your request. Please check it and help me to get final model in soild.
Cheers,
Jagan
Hi!
These surfaces struggled a lot toget well stitched, but VOILA!!!
I think this was a little dificult for you, because the program doesnt liked these particulary surfaces...
Ok, file attach, check it! (The file become too big, i w'll sent you by dropbox)
https://dl.dropboxusercontent.com/u/108503790/Model_4.ipt
Hi!
Like i said before, the 3D sketch was somehow inside the solid in some places and this was a problem in some operations.
Also, the model is very big, and to stitch the surfaces, i had to use a bigger tolerance (5mm unstead the inventor standard 0,2mm).
Also, is possible to do with loft, but not all at one time. I think the approach we use is more simple and direct (if you remember, we use now a lot less operations), the drawback is, we have to know some tools and processes a little out of "traditional" modeling.
Don't forget to close the case by Accept as Solution and give some kudos Kudos - in posts where you learn something, or where do you think that's important stuff to others, i appreciate that, Thanks.
PS: If you want the "core" and "cavity" of the mold, i can now do this for you easely, so, say something if you need it.
Glad to help you.
