Inventor Forum
Problem importing sketch to inventor 2013
14 REPLIES 14
Message 1 of 15
Barvas11
599 Views, 14 Replies
Hi Guys,
I have a problem importing an autocad sketch to inventor 2013. I get no errors. It just flashes and nothing happens. The options button is grayed out.
14 REPLIES 14
Message 2 of 15
JDMather
in reply to: Barvas11
Is this a new problem (did it used to work)?
Have you installed all Service Packs and Updates?
Did you ever get your DWG True View problem fixed?
http://forums.autodesk.com/t5/DWG-TrueView/DWG-TrueView-2013-64bit-installation-asp-net-4-problem/m-...
http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels%2Clocation&location=forum-...+
Did you install with UAC and anti-virus dissabled?
Can you attach the dwg file here?
The CADWhisperer YouTube Channel
Message 3 of 15
Barvas11
in reply to: JDMather
I have never tried in 2013 so this is the first time. I think that all service packs have been installed so it should be all up to date.
It doesn't work for any drawing file on the system. See attached.
Yes my true view works fine.
Message 4 of 15
JDMather
Can you attach screen capture?
Help>About Autodesk Inventor
Message 5 of 15
Barvas11
SEE ATTACHED
Message 6 of 15
JDMather
Try this first -
Update 4
Message 7 of 15
barvas
tried, restarted and still does the same thing.
Message 8 of 15
JDMather
in reply to: barvas
Can you verify that you are running DWG TrueView version 2013 (not 2014).
Message 9 of 15
barvas
yes it's 2013
Message 10 of 15
JDMather
in reply to: barvas
http://forums.autodesk.com/t5/Inventor-General/Importing-a-dwg-into-a-ipt/td-p/4702729
Replace the 2014 with 2013
Message 11 of 15
bob_holland
Jakub,
Are you trying to open the 2010 DWG or import it into a sketch?
I would think that you would want to import this into a sketch so that you can turn it into a part.
This will allow you to import DWG and DWF files into a sketch.
Can you please try this work flow and see it it works better for you.
Thank you.
Bob Holland
Autodesk Product Support
Message 12 of 15
johnsonshiue
Hi! When you imported the dwg file, did you see the following dialog? If yes, did you select the option as shown in the image? I have attached ipt file with the imported sketch for reference.
Thanks!
Software Test Engineer
Message 13 of 15
Barvas11
in reply to: bob_holland
Hi Guys,
I am trying to import 2d dwg sketch into ipt inventor sketch using the autocad icon button. I don't get any options dialog. As soon as I click OK it just flashes and nothing happens.
Work flow: open new ipt file > save it > go to sketch mode > click on the acad icon > select the dwg file > click ok
I am downloading a 2014 true view just now so I will let you know if it worked.
Message 14 of 15
Barvas11
OK, so here I am trying to install the true view 2015 as 2014 is no longer availible but there is a bug with mircosoft framework again it's asking me for 4.5 or higher version that I have just installed. It still doesn't like it.
Message 15 of 15
Barvas11
I will need a new version of Autocad 2015 in order to sort the true view issue. I cannot dowload it and install a trial as it won't let me due to error in dowloading @ autodesk grrrrr.......
They have known about the true view bug for 2 years and still haven't sorted it!
