Inventor General
Member
Message 1 of 5 (406 Views)
Problem importing 3D dwg solids to Inventor
406 Views, 4 Replies
07-17-2012 01:36 AM
Hello
I am having a bit a troubles with importing 3D solids to Inventor.
When I make 3D solids myself with autocad 2012 it works fine, but these solids I got appear scrambled.
See image.
Hope for some good explainations :smileyhappy:
WBR
T.J.A
Message 2 of 5 (391 Views)
Re: Problem importing 3D dwg solids to Inventor
07-17-2012 05:12 AM in reply to: Thorsteinnja
Attach the original dwg file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Member
Message 3 of 5 (387 Views)
07-17-2012 05:29 AM in reply to: JDMather
Thanks for the reply
Here is an example dwg
Distinguished Mentor
Message 4 of 5 (376 Views)
07-17-2012 06:29 AM in reply to: Thorsteinnja
You have objects that are either ~100 miles or ~7km away from the origin, depending on units.
Member
Message 5 of 5 (368 Views)
07-17-2012 06:51 AM in reply to: rdyson
Amazing really that that was the problem.
Thanks a lot for your reply
kudos!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
