Inventor Forum
Problem creating sweep with profile and 2d sketch...
4 REPLIES 4
hheng1111
1960 Views, 4 Replies
I have what i thought would be a simple sweep. I've created a profile for the sweep along with a path. As you'll see in the photo i've attached, i started the path on a projected plane that intersects the plane the profile was created on. When i click OK, I keep getting an error message that reads "Creat Sweep Feature: problems encountered while executing this command." I don't know why I'm getting this error, so could anyone shed some light on the issue?
Thanks in advance!
____________________________________________________________
HP Z400 Workstation
Intel Xeon @ 3.33GHz
12.0 GB RAM
Windows 7 64-bit
Inventor Pro 2015
4 REPLIES 4
dan_inv09
in reply to: hheng1111
From the picture it looks like you are in an assembly - cut is the only option not grayed out, and since it is trying to cut and there is nothing where you want to cut there is noting to cut.
(In a part it would probably be more descriptive, but the assembly people were apparently not allowed to borrow the part people's error messages.)
hheng1111
Thanks for your response. I hadn't noticed that cut was the only available option. I wasn't wanting to cut, but wanted to create tubing. why is it only giving me the option to cut?
HP Z400 Workstation
12.0 GB RAM
Windows 7 64-bit
Inventor Pro 2015
hheng1111
in reply to: dan_inv09
I hadn't realized that i needed to "Create" a part and then do the sweep. Problem solved. Thanks for bringing the "cut" problem to light. I wouldn't have figured it out without that info.
HP Z400 Workstation
12.0 GB RAM
Windows 7 64-bit
Inventor Pro 2015
dan_inv09
You can only cut when you are in the assembly, if you want to make something that goes in the assembly you need to make a new part.
You can use "create" on the assemble tab.
