Inventor Forum
Problem convert idw(drawing) to dwg (AutoCAD) with nut
2 REPLIES 2
rgruychev
1574 Views, 2 Replies
When i  convert   idw(drawing) to dwg (AutoCAD)  with Save as -> Save Copy as . I have problem with nuts
Inventor Professional 2013 update 1
see picture
2 REPLIES 2
rgruychev
in reply to: rgruychev
What to do? Does anyone have the same problem?
I also had this problem with a customer, i found that the template they where using was set to Imperial and they where using Metic content center Parts. Solution ensure that the assembly template is set to metric when using Metric content center components. when saved to Autocad DWG it is fine and act as it should. hope this helps
Ray
