Inventor Forum
Problem With Parametric Part and use Excel file in Inventor 2011?
8 REPLIES 8
Message 1 of 9
bms953
1342 Views, 8 Replies
in Inventor 2011, i use a Excel File (*.xls) for a part then after link in the parametric dialog box, i change many of number for test, but dos not happen for part, and after reopen diloag box, in user parameters i have many box with yellow color, i don't no why? i try any way to fix this but i can't
Please Help me
Behzad Meskini
Competitor in World skills Competition 2005 Finland (Mech,Eng,CADD)
Member of Iranian Elite Foundation
Autodesk Certified Professional-AutoCAD
Autodesk Certified Professional-Inventor Pro
Autodesk Certified Professional-3ds Max
Autodesk Certified Professional-Revit Architecture
Autodesk Certified Professional-Revit Structure
Autodesk Certified Professional-Revit MEP
DS CATIA Certified V5 Mechanical Surface Designer Specialist
DS CATIA Certified V5 Associate - Part Design
DS CATIA Certified V5 Associate - Surface Design
DS Solidworks-CSWP-Mechanical Design Professional
DS Solidworks-CSWA-Advanced Sheet Metal Professional
DS Solidworks-CSWA-Advanced Weldments Professional
DS Solidworks-CSWA-Advanced Surface Professional
DS Solidworks-CSWA-Advanced Drawing Professional
8 REPLIES 8
Message 2 of 9
JarFu
in reply to: bms953
Hi, I tried and also saw yellow cells (seems mean invalid). "Update" and "Change Source" don't work to discard them. The only way is to open the Parameters table, right-click the row which indicates the excel file, chose "Delete Folder", then "Link" this excel again.
Jar Fu
SW Engineer
Inventor QA
Autodesk, Inc.
Message 3 of 9
bms953
in reply to: bms953
i know, but it is not good, because i work on lot of file ( Assembly,Part,Weldment) in Inventor 2010, and now when i open that file , it does'nt work,
i create local library for my project with the parametric part link to excel, and i don't know what to do with this file, and relink excel file can''t fix all of them,
Behzad Meskini
Message 4 of 9
bms953
in reply to: bms953
i forget this, after change excel file and save in inventor update icon is still turn off
Behzad Meskini
Message 5 of 9
bobvdd
in reply to: bms953
This is a known problem.
We are working on a hotfix for this.
Best worarounds are to
a) relink to the same spreadsheet
b) edit the start cell and pick the exact same cell.
Sorry for the inconvenience.
Bob
Autodesk Inventor Product Support
Bob Van der Donck
Principal UX designer DMG group
Message 6 of 9
nickmartin
in reply to: bms953
I am doing a very large iPart now. After editing my excel spreadsheet and getting my changes made... In order to get them back to Inventor I have been first closing the file in Excel and then closing the Excel program. When exiting Excel it seems to apply my changes back to my Inventor table. It has been working for me...give it a try.
Message 7 of 9
bobvdd
in reply to: bms953
The hotfix is now available at http://usa.autodesk.com/getdoc/id=DL14965008
Bob
Bob Van der Donck
Message 8 of 9
kperic777
in reply to: bobvdd
This hot fix does not fix the problem.  See the attached.  That spread sheet is used on multiple parts (obviously), and it used to work, now it doesn't.  all yellow boxes, except the first three.  I tried making it all one sheet and all kinds of stuff.
WINDOWS 7
INVENTOR SIMULATION 2011
EXCEL 2010
Please let me know your thoughts...
Message 9 of 9
kperic777
in reply to: kperic777
i should let everyone know that i just figured out a very effective work around for this, that automatically fixes it.  I saved Copy As my formula-heavy excel spread sheet as a different name.  then i overwrote the old one as the attached.  the attached are my parameters and values column pasted into a blank spread sheet as TEXT ONLY.  this seamed to clear things up.  Now, i edit the calculation (formula-heavy) spreadsheet, paste the resulting valvues into the attached as TEXT ONLY, and it works.  no need to "delete folder" or "rename parameters" or anything too combursome.
Now, i want to understand:  WHAT WENT WRONG??
the problem with these work arounds are that i now need to tell all the engineers in our company this process, and make sure everyone is on board...and i still question the stability of the spreadsheets.  which is a shame, because driving multiple parts with one sheet would be ideal for us.
