This hot fix does not fix the problem. See the attached. That spread sheet is used on multiple parts (obviously), and it used to work, now it doesn't. all yellow boxes, except the first three. I tried making it all one sheet and all kinds of stuff.
WINDOWS 7
INVENTOR SIMULATION 2011
EXCEL 2010
Please let me know your thoughts...
i should let everyone know that i just figured out a very effective work around for this, that automatically fixes it. I saved Copy As my formula-heavy excel spread sheet as a different name. then i overwrote the old one as the attached. the attached are my parameters and values column pasted into a blank spread sheet as TEXT ONLY. this seamed to clear things up. Now, i edit the calculation (formula-heavy) spreadsheet, paste the resulting valvues into the attached as TEXT ONLY, and it works. no need to "delete folder" or "rename parameters" or anything too combursome.
Now, i want to understand: WHAT WENT WRONG??
the problem with these work arounds are that i now need to tell all the engineers in our company this process, and make sure everyone is on board...and i still question the stability of the spreadsheets. which is a shame, because driving multiple parts with one sheet would be ideal for us.
