Inventor Forum
Problem Using Blocks In Sketches
1 REPLY 1
matt_jlt
195 Views, 1 Reply
Every now and then I (and others I work with) seem to have this very annoying problem with using blocks in sketches that are then derived into another part and extruded.
If you modify the Master Skeleton Sketch and it contains blocks, all of the parts that are linked to those sketches show errors when the parts update and you have to either go into each part and run rebuild part command or edit the sketch and either double click a dimension (reference dimensions only as it is a derived sketch) and click ok. You dont have to change anything, just have to make the sketch fix it's self.
It is very time consimung when you have any where between 25 to 50 parts in an assembly and this problem happens a few times in a row.
Any ideas from anyone?
Cheers, Matt.
1 REPLY 1
liang_chen
in reply to: matt_jlt
Hi Matt,
Appreciate for your report !
I try some cases as your description, but unfortunately I can't reproduce your issue.
Sometiimes, it may be very hard for us to reproduce customers issue if can't get the original files
Could you please attach your sample case? It will be helpful for us to investigate your issue
Thanks for your report again
Fred
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
