Inventor Forum
Problem - Import DWG to Inventor
14 REPLIES 14
Message 1 of 15
LEOALEX
2428 Views, 14 Replies
I,
Please, i need importa dwg to inventor for create a solid.
The problem is when a import the file, in the "layers and objects import options" , inventor don't show me some layers present in the dwg.
It is a problem?? or i need configurate anything???
14 REPLIES 14
Message 2 of 15
JDMather
in reply to: LEOALEX
Something isn't right here.
Attach the dwg file here to see if others can reproduce the behavior.
Message 3 of 15
BMiller63
I've had that happen and I THINK (I can't recall for sure) that unchecking the ALL checkbox was the trick. I may be wrong though.
Message 4 of 15
LEOALEX
in reply to: BMiller63
desable the option "all", but the problem continue. I used drawing of the folder sample of mechanical. Attch have one sample.
Message 5 of 15
JDMather
Worked fine here.
What version of Inventor and AutoCAD do you have installed?
Message 6 of 15
LEOALEX
in reply to: JDMather
Autodesk Inventor Professional 2011 SP1. Mechanical 2011. 😕
Message 7 of 15
JDMather
Does the problem persist after rebooting the computer?
Message 8 of 15
LEOALEX
yes, the problem is old. I know if have hotfix for the problem?
Message 9 of 15
LEOALEX
yes, the problem is old. I don't know if have hotfix for the problem?
Message 10 of 15
BMiller63
I know I had this issue, and I tried several things, I just don't recall what worked.
Some things to try:
  • If running on Windows 7, close Inventor, and then restart it by rightclicking the shortcut and picking "run as administrator"
  • go to the tools tab and click the Add Ins button and make sure the DWG translator is loaded
Message 11 of 15
yannick3
Hi
I think your dwg trueview installation is corrupted try to uninstall/reinstall it
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Message 12 of 15
BMiller63
no solution, but here is the same problem:
http://forums.autodesk.com/t5/Autodesk-Inventor/importing-DWG-files-problem/m-p/2725569/highlight/tr...
also a couple of things to try here:
http://forums.autodesk.com/t5/Autodesk-Inventor/Importing-AutoCAD-DWG-to-Inventor/m-p/2543467/highli...
including just copying the geometry in AutoCAD and Pasting into Inventor.
Message 13 of 15
LEOALEX
I reinstall dgwtrue view, bat AIP show me a error.
I attech the picture of the error!!
the problem continue... 😕
Message 14 of 15
yannick3
Hi
Have uninstall before
uninstall all dwg trueview release before fresh install you can download it
http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&siteID=123112
i've seen this issue before and the problem is dwg trueview corrupted.
Yannick Verreault
INV PRO 2015
MS Office 2007
WD caviar black 1To
Message 15 of 15
Mingo13
I have litle bit difrent problem.
When i try import dwg files to inventor, won't show popup window with "setings" and nothing's more happen (see video on link:http://www.youtube.com/watch?v=tHyfQ8kDN7s&feature=youtu.be ). But when i try open dwg files everything works fine. Have anyone any solution for this issue?
