Inventor General
Active Member
Ann-Longstaff
Message 1 of 6 (1,357 Views)
Problem - Import DWG into Inventor Sketch - Layers unavailable
1357 Views, 5 Replies
01-27-2012 02:11 AM
A couple of days ago when I went to shut down my computer ran windows updates automatically and the next morning these updates failed and the previous setting were re-configured. Windows updates ran again the next night and updated sucessfully.
Since then I have been having problems importing autocad into a sketch. In the Layers and Objects Import Options dialog box, the layers are not shown and the autocad objects can not be individually selected.
Having searched on here and it seems to suggest a problem with either AOEMViewer or DWG TrueView corrupting, although some people after uninstalling and reinstalling these viewers still experienced the problem.
I was wondering if this is the solution to the problem or if there is a hotfix to solve it without having to un/reinstall programs.
Ann Longstaff
Inventor Suite 2010 SP4
Windows 7 Pro SP1 64-bit
Active Member
Ann-Longstaff
Message 2 of 6 (1,335 Views)
Re: Problem - Import DWG into Inventor Sketch - Layers unavailable
01-30-2012 01:43 AM in reply to: Ann-Longstaff
I was just wondering if anyone else has come across this problem and has a definite solution.
Ann
Message 3 of 6 (1,326 Views)
01-30-2012 03:32 AM in reply to: Ann-Longstaff
Seems like you may need to reinstall DWG Trueview.
Employee
jeffrey.sun
Message 4 of 6 (1,303 Views)
02-01-2012 10:33 PM in reply to: Ann-Longstaff
The versions of Inventor and DWG True View must match with each other. Which version of DWG True View are you using? The expected version should be 2010.
It seems your issue is similar with that described here (http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17197674&linkID=9242018).
Jeffrey Sun
SW Engineer
Manufacturing Industry Group
Active Member
Ann-Longstaff
Message 5 of 6 (1,293 Views)
02-02-2012 12:54 AM in reply to: jeffrey.sun
Inventor and DWG True View both 2010, and installed from the same Inventor disk.
Thanks for the link, I will look into that as it does seem to described my problem.
I did do a good search on different descriptions but it's a mine field on here really!
Ann Longstaff
Active Member
Ann-Longstaff
Message 6 of 6 (1,265 Views)
02-07-2012 07:33 AM in reply to: jeffrey.sun
Jeffrey,
Thank you for the link.
IT has now worked through the solution and Inventor is now working correctly.
I appreciate your help.
Ann
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
