Inventor General
Member
Message 1 of 13 (192 Views)
Problem -- Hard-Coded Sketch Start Plane
192 Views, 12 Replies
04-26-2012 06:27 AM
We are using Inventor 2012.  For everyone in the department, when starting a new sketch, it is always starts in the X-Z plane (upside down TOP).  Changes in "Application Options", "Part", "No New Sketch" have no effect on our individual computers.  This appears to be hard-coded in some master set-up file.  We would very much like to be able to pick our sketching plane.  Thanks.
Valued Mentor
RayFeiler
Message 2 of 13 (190 Views)
Re: Problem -- Hard-Coded Sketch Start Plane
04-26-2012 06:33 AM in reply to: gmckewan
So changing this setting doesn't work for you?
It's working for me.
Product Design Suite Ultimate 2014 64-Bit
Sometimes you just need a good old reboot.
Member
Message 3 of 13 (185 Views)
04-26-2012 06:36 AM in reply to: RayFeiler
No. It just ignores what we pick for the start plane and starts us on the X-Z.
Valued Mentor
RayFeiler
Message 4 of 13 (181 Views)
04-26-2012 06:40 AM in reply to: gmckewan
Have you installed SP1?
I have SP1 + DL17804875, DL17804781 & DL17690625 hotfixes install on my machine.
Valued Contributor
Secttor
Message 5 of 13 (179 Views)
04-26-2012 06:41 AM in reply to: gmckewan
we hope SP1 for Inventor is installed on your machines.
Draftworks.wordpress.com
Member
Message 6 of 13 (176 Views)
04-26-2012 06:43 AM in reply to: gmckewan
Yes, we all have SP1 installed.  Is there some master setup file? Or Administrator file that we don't know of?
Valued Mentor
RayFeiler
Message 7 of 13 (174 Views)
04-26-2012 06:47 AM in reply to: gmckewan
Not that I'm aware of. Do you also have the hotfixes installed?
Member
Message 8 of 13 (172 Views)
04-26-2012 06:56 AM in reply to: RayFeiler
Not sure about the Hotfixes.  The Dept. switched to Inventor about 3 years ago.  A consultant came in and set us up.  This problem has existed ever since and through each update of Inventor.  That is why I think it has to be hard-coded somewhere in some master file setting.
*Expert Elite*
Message 9 of 13 (155 Views)
04-26-2012 08:39 AM in reply to: gmckewan
I have several part templates set up, one for starting on the XY, one for starting on the XZ, one for starting on the YZ, and one with no starting sketch.  The one with no starting sketch is set up as my Standard.ipt template, because this is what is used when I derive a part or create a new file inside an assembly.
You could try setting up templates this way to see if it changes the behavior you see.
Valued Contributor
mbenoy
Message 10 of 13 (139 Views)
04-26-2012 10:19 AM in reply to: gmckewan
I think the problem is that the template you're using already has an active sketch.
Michael Benoy
Designer
Scott Safety
Inventor 2012 Pro, Windows 7, 64bit
Intel® Xeon® Processor W3580 (8M Cache, 3.33 GHz)
12 GB DDR3, NVIDIA Quadro FX 3800
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
