Inventor Forum
Problem Download Update 2 Service pack 1 inventor 2014
12 REPLIES 12
Message 1 of 13
akhidrosyidi
1860 Views, 12 Replies
hi all,
I try to download update 2 SP 1 Inventor 2014 with this link
http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/update-2-in...
But when i click
DL-22744369.zip (zip - 16351Kb)
always redirect to http://knowledge.autodesk.com/
Please, help.
daily works with :
Autodesk Inventor Profesional 2014.
AutoCAD Mechanical 2014.
Autodesk Vault Profesional 2014.
12 REPLIES 12
Message 2 of 13
blair
in reply to: akhidrosyidi
Try this: http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/autodesk-in...
then this one: http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/update-2-in...
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 13
RockDr
in reply to: blair
The links blair provided work for SP1 but the original poster was correct that there is a problem with the page on the new web site that has the Update 2.    This update should be available through the Liveupdate feature of the product, but we'll get the web page fixed no later than tomorrow.
Message 4 of 13
akhidrosyidi
in reply to: blair
thanks for your respon,
but curently I was install Inventor 2014 SP 1,
when i try to download with this link ( i copas from your comment)
i can not download this, because link redirect to http://knowledge.autodesk.com.
daily works with :
Message 5 of 13
akhidrosyidi
in reply to: RockDr
Thanks RockDr
daily works with :
Message 6 of 13
wrighte
Thanks for this feeedback.  We're working to correct the file links for that servcie pack and troubleshoting what happened to break them when migrating to the new site in the first place.
Eric Wright
Sr. Web Product Manager
Autodesk Knowledge Network
Message 7 of 13
in reply to: RockDr
Just an FYI --- the link is still broken!
It goes to this page:
http://knowledge.autodesk.com/ooooops
 Edit: Sorry, I thought that was posted on 2-09, but now I see it was posted today (2-12).  Just frustrated that there is confusion on which update 2 actually fixes the problem.  Would have been nice if the fixed update had been named 2.1 or even 3.
Message 8 of 13
RockDr
The page has been corrected and is available at this URL:
http://knowledge.autodesk.com/article/DL22744369
or the full URL of the page is
thanks for your patience.  It did indeed take longer than my previous post anticipated.
Message 9 of 13
Maxim-CADman77
in reply to: RockDr
I wonder is it still that "improved second" version of Update 2 for SP1
...or is it the "first version" ... or may be already 3rd version?
Firstly published version was DL22744369.zip
Second contained dash in filename "DL-22744369.zip"
Now filename is again dash-less "DL22744369.zip".
...seems like somebody is kidding...
Message 10 of 13
My congratulations - it is third version of Udpate 2 SP1 (I've compared its content with both previous and it does differ from both).
Well not update but readme was changed
Statement
"FEA Results incorrect compared to previous releases"
was replaced with
"Bonded contacts between cylindrical and planar faces can cause the geometry to behave overly stiff near the area of contact"
no comments
Message 11 of 13
You are correct. The Update has not changed, only the readme. This was done a few weeks ago to more accurately describe the change included in Update 2.
thank you,
David
Message 12 of 13
roger
in reply to: david.harris
Should I install this update for Inventor 2014 LT? it is not listed under the applications.
Roger
Message 13 of 13
david.harris
in reply to: roger
Hi Roger,
This Update does not apply to the LT product.
Best regards,
David
________________________________
Autodesk Limited
Registered Office: One Discovery Place, Columbus Drive, Farnborough, Hampshire GU14 0NZ
Registered in England and Wales, No. 1839239
