Inventor Forum
Print screen?
13 REPLIES 13
Message 1 of 14
1683 Views, 13 Replies
Print screen?
Trying to print a screen image of a Inventor dialog box. Using Windows 2K
Pro, no SP's. Looked in the windows help files, no help there? BTW, would
installing the windows SP's improve inventor's performance?
Thanks, Bob
13 REPLIES 13
Message 2 of 14
just press the Print Screen button on your keyboard, then go into MSPaint or
whatever and press Paste (CTRL-V)....
installing SP's is recommended, for sure... (if for nothing else but
security).
Message 3 of 14
Try this; it should work...
Get your screen looking the way you want it (mind where your mouse curser is
placed), then: Control+Print Screen. This sends the screen image to
clipboard. Open MS Paint, and paste as a new document. Then you can print
from there. The old Print Screen command was a DOS thing; Windows takes an
extra step.
As for the SPs, I've always kept current on them. I know with earlier
versions of Inventor that having the latest Windows service packs helped
performance. I assume it's still true.
Cheers,
Walt
"Bob Johnson" wrote in message
news:DB8D7A6620E75C6CDDEB54179620E216@in.WebX.maYIadrTaRb...
> Thanks, Bob
Message 4 of 14
I've got the following info from Windows 2000 Help:
To make a copy of only the active window,
press ALT+PRINT SCREEN.
To copy the entire screen as it appears on your monitor,
press PRINT SCREEN.
The CTRL key seems like a no-op in this case
(i.e., CTRL+PRINT SCREEN = PRINT SCREEN).
Glenn
"Walt Jaquith" wrote in message
news:B729B851B2AA1EC2E30C907CD7D212FB@in.WebX.maYIadrTaRb...
is
print
an
> extra step.
> Cheers,
> Walt
2K
would
> > Thanks, Bob
Message 5 of 14
Use this to make a copy of your application options settings, then if you
crash or reinstall you have an easy copy.
Laurence,
Power is nothing without Control
"Glenn" wrote in message
news:75A7D51B2BEB40A9FF87C1E84CEDDA3D@in.WebX.maYIadrTaRb...
> Glenn
Message 6 of 14
jiml
or get snagit I love snagit
see it at http://www.techsmith.com
Message 7 of 14
MechMan_
To do a print screen of a dialog box press Alt+Print Scrn and then paste the image where you want it.
MechMan
Message 8 of 14
MechMan_
I do this for most of my software that I have customized settings for. Create a Word document (for example) and Alt+Prt Scrn from the app settings to the Word doc. Quick and easy.
MechMan
Message 9 of 14
Oops. You're right. A long time ago, I saw an IT guy Ctrl+Print Screen,
and I've been doing it every since.
Funny, some of the stuff we 'know' sometimes. Sorry about the bad info.
Walt
> press PRINT SCREEN.
> Glenn
Message 10 of 14
Or if you are on a budget try http://www.mirekw.com/ MW Snap Does nearly everything I
need from a screen capture program. 8^)
Kent
Member of the Autodesk Discussion Forum Moderator Program
"jiml" wrote in message news:f122a45.4@WebX.maYIadrTaRb...
Message 11 of 14
FYI: print screen images are in BMP format which is rather large. A word
doc can get mighty large with these screen caps. For my tutorials I paste
them into paint then save as JPEG and then repaste into Word. It reduces
the file sizes by 1/5 of the old size in many cases....
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
> Thanks, Bob
Message 12 of 14
MechMan_
For posting to the internet you're exaclty right. For a doc I keep on my HD for my own use Cut/Paste bmp's is easier. I've got the HD space.
MechMan
Message 13 of 14
Sean,
You're right about JPEG file size being much smaller than BMP file.
But I'm not sure about inserting JPEG into Word. This is what I
found from a little experiment:
1. Alt+Print Scrn > Paste into Paint >
> Save as 24-bit BMP (BMP file size = 2,417 KB)
> Insert BMP file into Word (DOC file size = 85 KB)
2. Alt+Print Scrn > Paste into Word (DOC file size = 85 KB)
3. Alt+Print Scrn > Paste into Paint >
> Save as JPEG (JPEG file size = 161 KB)
> Insert JPEG file into Word (DOC file size = 181 KB)
Glenn
"Sean Dotson" wrote in message
news:471DB77BD015B9476882604BF0EDD788@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
Message 14 of 14
Hmm...It's been a while but I was having problem with my Word docs getting
to be 100+MB. I don't recall the exact prodeduce but there is a difference
between cut and pasting in a JPEG and insert from a file I belive.
My experiment: (all in kB)
JPEG Size: 245
BMP Size: 3841
GIF Size: 299
BMP Pasted into Word: 4,189
BMP Inserted in Word: 173
JPEG Pasted into Word: 5,335
JPEG Inserted in Word: 266
GIF Pasted into Word:1,846
GIF Inserted in Word: 292
I guess I was rememebring wrong. It must have been GIF files I used...
I forget all of that color math I used to know and how to optimize image
sizes....
Sean Dotson, PE
news:4393E17DD56D3A299EF67F0DD14E3DCE@in.WebX.maYIadrTaRb...
> Sean,
> Glenn
word
paste
reduces
> > Sean Dotson, PE
