2nd try....
Dennis Jeffrey, AICE, MICE
260-312-6188
Instructor/Author/Sr. App Engr.
Inventor 11 Professional SP2, MDT 2007 SP1
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
"Dennis Jeffrey" wrote in message
news:5546572@discussion.autodesk.com...
Have you checked these settings in Tools > Application Options > Drawing?
260-312-6188
wrote in message news:5546269@discussion.autodesk.com...
Thank you for your thorough response. I followed your instructions, and
replaced one of the two "Object Defaults" Styles, and then tried thickening
my visible lines.
However, the change was not reflected in my display, despite having "Show
Line weights" checked in App.Options->Drawing.
The thickened lines are displayed for brief flashes at random intervals, and
for a few milliseconds when I drag a view across the sheet and set it in
another location.
This behavior is the same whether I use my pre-existing drawing and styles,
when I open an example drawing, or when I use the default project, the
styles installed by Inventor, and a brand new simple cube created with the
freshly installed Inventor default part and IDW templates.
I'm not sure if the non-display of line weight is related to my printing
problem, but it seems likely.
