Inventor General
Contributor dgi
dgi
Message 11 of 30 (74 Views)
Re: Print Problem - Dashes Disappear
04-06-2007 08:43 AM in reply to: dgi
Aardvark, thank you for the pointer. Unfortunately, even when I follow those instructions and delete those registry keys, I still immediately have the problem that all my lines become solid. I guess I need to reformat my hard drive again and then get a new computer.
*Dennis Jeffrey
Message 12 of 30 (74 Views)
04-06-2007 12:28 PM in reply to: dgi
That is correct... not sure what is going on there... can you post or email
me your files? (Zipped of course)
Dennis Jeffrey, AICE, MICE
260-312-6188
Instructor/Author/Sr. App Engr.
Inventor 11 Professional SP2, MDT 2007 SP1
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
wrote in message news:5544167@discussion.autodesk.com...
Dennis:
Thanks for your suggestion. I'm not sure if I understand. When I go to
Styles Editor, and click the "Layers" TreeView, I can look at my current
Layer Styles. When I edit this style, all the "Scale by Line Weight" boxes
ARE checked. I think this is what you meant for me to check.
*Dennis Jeffrey
Message 13 of 30 (74 Views)
04-06-2007 12:30 PM in reply to: dgi
I doubt that there is a need to read format your hard drive or even to
reinstall inventor and all the service packs. There is something else going
on here, and it's probably related either to your workflow, or to your
styles Library.
260-312-6188
wrote in message news:5544168@discussion.autodesk.com...
Contributor dgi
dgi
Message 14 of 30 (74 Views)
04-06-2007 04:12 PM in reply to: dgi
Mr. Jeffrey:
Thank you for your interest. I still don't know why I am having this printing problem. I am attaching my styles. My whole department uses these styles and I get them off a file server.
*Dennis Jeffrey
Message 15 of 30 (74 Views)
04-06-2007 08:16 PM in reply to: dgi
OK.. got the styles... can toy send a corresponding IDW that exhibits this
behavior?
260-312-6188
wrote in message news:5544621@discussion.autodesk.com...
Mr. Jeffrey:
*Dennis Jeffrey
Message 16 of 30 (74 Views)
04-07-2007 05:14 AM in reply to: dgi
Sorry, my fingers got in the way of my typing. Can you post or send me some
example files-IDW and part file?
260-312-6188
"Dennis Jeffrey" wrote in message
news:5544724@discussion.autodesk.com...
behavior?
260-312-6188
Mr. Jeffrey:
Contributor dgi
dgi
Message 17 of 30 (74 Views)
04-08-2007 03:43 PM in reply to: dgi
Thanks for your patience.
I'm attaching an IDW/part file that I have been opening each time I change something, to see if my dashed hidden lines have come back. But each time, they still don't print.
However, I don't think the IDW is the problem. I can open the same file on my neighbor's computer just fine, and print it with the dashed lines intact. And even when I create a new part and new drawing from scratch using my computer, the hidden lines print as solid.
The remaining possibilities are that my configuration is broken, or that my computer hardware is different. The configuration is the same because we are both using the same Windows/Inventor install disk, the same service packs, the same styles and the same printer driver (Ghostscript/CutePDF).
Therefore, there must be something wrong with my computer. This is my computer:
Asus A8N-SLI NForce4 Motherboard
AMD Athlon64 X2 4400+
2 GB Crucial D400
PNY Nvidia Quadro FX 540 PCI Express x16
80G Seagate Barracuda SATA HD
Any other ideas? It seems I will have to throw these away and start over if I want to use Inventor.
*Dennis Jeffrey
Message 18 of 30 (74 Views)
04-08-2007 08:01 PM in reply to: dgi
I'll take a look later tonite.....
260-312-6188
wrote in message news:5545310@discussion.autodesk.com...
The remaining possi
computer:
2 GB Crucial D400
80G Seagate Barra
cuda SATA HD
*Blair A. Stunder
Message 19 of 30 (74 Views)
04-08-2007 11:32 PM in reply to: dgi
I can print to fit on my Dell 1700 with lighter lines for Hatch, Hidden,
Center, Dims and the Title block boarder is lighter than the Boarder, but if
I print using Adobe Acrobat 6.0pro it crashes Adobe and I get a file dump
into notepad, strange....
Blair
news:5545418@discussion.autodesk.com...
260-312-6188
The remaining possi
computer:
2 GB Crucial D400
80G Seagate Barra
cuda SATA HD
*Dennis Jeffrey
Message 20 of 30 (74 Views)
04-09-2007 08:26 AM in reply to: dgi
The problem that you are having is related to linewidths in your Drawing
Style. While you have many linwidths set to .020, you have the Visible
Edges-PIG set to .014. I changed the linewidth to .028, and got the attached
result.
If you like, you may download a video of this at:
http://teknigroup.com/AUGI/Videos/layerstyles.zip
260-312-6188
The remaining possi
computer:
2 GB Crucial D400
80G Seagate Barra
cuda SATA HD
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
