Inventor General
DocGreen
Message 1 of 6 (99 Views)
Previous Drawing Show in Later Drawings (without being visible)
99 Views, 5 Replies
09-24-2012 11:37 AM
Why do some drawings show in later drawings even through I have them set to invisible? I cannot find a consistent reason and the only way to "fix" it seems to be to delete the old drawing and redo it.
*Expert Elite*
JDMather
Message 2 of 6 (95 Views)
Re: Previous Drawing Show in Later Drawings (without being visible)
09-24-2012 11:41 AM in reply to: DocGreen
Can you post a "drawing" that exhibits this behavior?
I read this several times and still don't understand the problem statement.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
DocGreen
Message 3 of 6 (93 Views)
09-24-2012 11:44 AM in reply to: JDMather
Unfortunately, I cannot.
If you have a part with 10 drawings ordered 1 - 10, drawing 3 may be visible in all later drawings save the newest (4 - 10). At the same time, the curves from drawing 4 don't exibit the same behavior. Having curves visible is expected when the drawing is visible, but why does the behavior occur when the drawing is not visible? I am using the student edition.
*Expert Elite*
mrattray
Message 4 of 6 (82 Views)
09-24-2012 12:17 PM in reply to: DocGreen
I think you need to review the terms you're using, I don't think you are using the term "drawing" correctly. A drawing refers to an .idw (or Inventor .dwg) file. "Parts" are .ipt files. Assemblies are .iam files.
I also doubt you are using the term "curve" correctly.
If I'm wrong and you do know the correct terminology than a better explanation, maybe with pictures, is going to be needed. I don't think anyone is understanding your problem statement.
Mike (not Matt) Rattray
DocGreen
Message 5 of 6 (79 Views)
09-24-2012 12:21 PM in reply to: mrattray
Ok, by "inventor" terms I mean sketch.
DocGreen
Message 6 of 6 (74 Views)
09-24-2012 12:31 PM in reply to: mrattray
If you have a part file with 10 sketches ordered 1 - 10, sketch 3 may be visible in all later sketches (4 - 10) save the newest, but sketch 3 is always kept "invisible." At the same time, the curves from sketch 4 don't exibit the same behavior. Having curves visible is expected when the sketch is visible, but why does the behavior occur when the sketch is not visible? I am using the student edition.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
