Thanks for the quick response Andy, how do I separate the tweaks?
I've tried applying one to get the 2200mm movement then I set the tweak for
the other component. When I then set the tweak for the continued movement of
component A and then play back, the first tweak runs right to the end before
component B has had a chance to move out of the way.
Goodness me, what a ramble, sorry about that!
Simon.
"Andrew Faix (Autodesk)"
wrote in message
news:EA6F028B2DFE4F205FEC70555B06FBC4@in.WebX.maYIadrTaRb...
> the quick answer is yes.
> It shouldn't be any more complicated than adding 3 distinct tweaks in the
> order that you described.
> "S.P.I.T." wrote in message
> news:0B50AB86EE11C9EADA3C2CD0D8114B14@in.WebX.maYIadrTaRb...
> > Hello to all,
> > Is there any way to separate a directional tweak into two?
> > I have component A travelling along a plane for 2200mm. I want it to
pause
> > while component B moves on another plane and then for component A to
> > continue on it's way for another 4000mm.
> > Am I totally missing something here or is it not do-able.
> > TIA,
> > Simon.
