Tero,
I have tried this in r11 sp2. I am not sure what release you are uisng but
please try the following suggestion if you are in r11. If you create an
iAssembly of your weldment assembly, you can create a new row and select
your assembly parts. In that row, there are options to include or exclude
certain parts. For your situation, exlcude all the parts with the exception
of the individual part you want to see. Save the Assembly. In your
drawing, create a view. Before placing it, select the Model State tab and
you should see an area in the middle of the dialog called iAssembly Member.
Select your row that you set for your individual part. Place the view. Now
in the Drawing Annotation Panel, select parts list and select your view of
that iAssembly member. Your parts list should display that part only.
Please let me know if this does not work.
Lisa Darrah
Autodesk Inventor Quality Assurance Engineer
wrote in message news:5328641@discussion.autodesk.com...
How to do this?
I have a weldment assembly, with several preparations. How to create a
drawing of one individual part, all of its preparations visible and part
list showing only this part? Also, this part have it's own part number I
need to show on title block.
I know the usage of different welding environment stages, only thing missing
is how to create a single part preparation drawing described above.
Virtual beer for the best suggestion,
Tero
