Inventor Forum
Precise input menu
11 REPLIES 11
Message 1 of 12
brian
1212 Views, 11 Replies
Precise input menu
Hello group
I ran across something I not seen before.  My precise input is missing the windows or boxes that let me enter x and y coordinates. See attached.  I've done repair, control panel, program features, Autodesk inventor 2012, repair.  And that worked for a few hours.  It's been missing after that, re-running repair has not brought it back.  I'm questioning if a re-install would fix the problem.  And if so, what is necessary to re-use my standalone license.
Thank for your help
Brian Brisbin
Windows 7 sp1 64 bit
6gb ram
11 REPLIES 11
Message 2 of 12
Dennis_Jeffrey
in reply to: brian
Did you do your original install uusing these instructions?
http://teknigroup.com/support/InstallAdsksoftware.html
If so, then we need more system information
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Message 3 of 12
silverprl1
in reply to: brian
Mine is missing on two machines as well. After service pack 1 and definitely did not return with service pack 2. And yes, I installed per the UAC off et all instructions.
Message 4 of 12
in reply to: Dennis_Jeffrey
Hi Dennis,
I have the same problem, what information is required in order to solve the problem?
Message 5 of 12
Ray_Feiler
http://forums.autodesk.com/t5/Autodesk-Inventor/RIP-Dennis-Jeffrey/td-p/3083872
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 6 of 12
JDMather
First of all, what version of Inventor are you running and what are your system specs?
Have you installed all Service Packs for your version?
Is this a new problem (did it work previously)?
Did you install with anti-virus (including TSR) and UAC off?
Can you post a screen capture of this while in an active 3D sketch?
Message 7 of 12
thuffam
in reply to: brian
Did anyone find a solution to this?  If so please post.
Message 8 of 12
JDMather
in reply to: thuffam
Q1 First of all, what version of Inventor are you running and what are your system specs?
Q2 Have you installed all Service Packs for your version?
Q3 Is this a new problem (did it work previously)?
Q4 Did you install with anti-virus (including TSR) and UAC off?
Q5 Can you post a screen capture of this while in an active 3D sketch?
Message 9 of 12
silverprl1
in reply to: JDMather
Yes - Inventor 2011 installed correctly. Begins to malfunction with Service Pack 2 and AutoCAD 2011 installed. Completely breaks when any 2012 software package is installed. Had to roll back the install to 2011 with no service packs to restore order, and ditch all 2012 products.
One MAJOR problem with 2011 is exporting flat drawings in the 2007 format for CNC. Beginning in service pack 2, and getting worse with 2012, exporting flat docs meant that Inventor was exporting every visual item as if it were a closed vector. Construction lines, dimension lines, connection points - all became exported vectors. A line with a dimension exports the line, a second line underneath representing the virtual dimension line, the dimension markers, and any angle references as well.
Service pack 2 on 2011 onward is useless for CNC exporting.
And yes - the precise input goes away at the same time these other issues appear.
This is on a dual quad-core Dell Certified Workstation with WIN 7, 12GB SDRAM, etc... I have done at least 2 dozen installs with UAC controlled machines.
Message 10 of 12
PACDrafting
in reply to: silverprl1
Autodesk why is this happening?????? Fix it!
Using a Quadro FX 1800 card. Not a great card but its tested by Autodesk.
Why is the precise input X,Y,Z input areas missing on some occassions?
Requires a reboot to fix it!
Message 11 of 12
PACDrafting
in reply to: PACDrafting
OK I've found the issue.
If you leave the precise input toolbar on and exit inventor then reopen inventor. The inputs arent available.
If you close the precise input toolbar before exit. Then exit then reopen it is fine.
So its an Inventor issue, not video card problem.
Message 12 of 12
Thank you so much.
This solution works perfectly.
I continually find these types of anomolys in Autodesk producrs. We have to use this for PLTW. I'm continually suprised that Autodesk ships such idiosyncratic applications.
