Inventor Forum
Precise input icon grayed
14 REPLIES 14
Message 1 of 15
bdaniels80
2998 Views, 14 Replies
I am using Autodesk Inventor 2013 and for some reason I cannot access the precise input option.  I can find the icon in the draw box, but it is grayed out and not clickable.  Am I doing something completely wrong?  Thanks for your help!
14 REPLIES 14
Message 2 of 15
Ryan.Martinez
in reply to: bdaniels80
Post a screen shot, not exactly sure what you mean.
P.D.S. 2015
P.D.S. 2016
Message 3 of 15
bdaniels80
in reply to: Ryan.Martinez
Message 4 of 15
Ryan.Martinez
You have to activate a command first... Like line
P.D.S. 2015
P.D.S. 2016
Message 5 of 15
bdaniels80
Ahhhh, I knew I was just doing something stupid.  Thanks so much!
Message 6 of 15
Ryan.Martinez
haha no prob
P.D.S. 2015
P.D.S. 2016
Message 7 of 15
SBix26
Not to be too smart-aleck, but in 99.99% of modeling tasks with Inventor, using the Precise Input box would be completely wrong.  I last used it, I believe, in my first evaluation of Inventor eleven years ago, before having any training.
What are you doing that needs the PI box?
Message 8 of 15
JDMather
in reply to: SBix26
I last used it in 2001 or 2002 (v5).
I don't think I have even showed my students that it exists in the past 7 or 8 years.
Message 9 of 15
Ryan.Martinez
in reply to: JDMather
I did not even notice it's exsistance untill i read this post.
P.D.S. 2015
P.D.S. 2016
Message 10 of 15
tuiengr
in reply to: SBix26
I'm trying to use precise input to establish points for a 3D wire path.  I hope to be able to sweep a path around pulleys to mimick the wire path.  My attempt is to draw circles about each point to represent the root groove of my pulley and then to draw 3D lines tangent to the circles.
So far I have not been that successful with this approach.  I entered an intermediate point incorrectly and trying to "reposition" via the 3D Move / Rotate command has been difficult, other points move erractically it seems.
Inventor 2013 Professional SP1
Windows 7 Profession, 64-bit SP1
Intel Core i5 CPU, 8GB RAM
NVIDIA Quadro 600, 4800 MB
Message 11 of 15
Ryan.Martinez
in reply to: tuiengr
Post a copy of your file or atleast a screen shot. Also the version of inventor you are using.
P.D.S. 2015
P.D.S. 2016
Message 12 of 15
SBix26
I'd strongly recommend using 2D sketches to control 3D sketches and/or points.  Much more robust and much easier to control and adjust for design changes.
Message 13 of 15
tuiengr
Inventor 2013 HP Z200 Workstation Intel(R) Core(TM) i5 CPU 8.00 GB RAM 64-bit Operation System
Message 14 of 15
JDMather
Imagine that you were doing a 2D drawing back on the drawing board or in AutoCAD.
sketch what that 2D drawing would look like from the top view (in a 2D sketch).
Exit sketch.
Now go to the front view, start a new sketch and sketch what that 2D drawing would look like from the front view (in a 2D sketch).
(an alternative would be top and right side view or front and right side view - whichever two views would be easiest to create on the drawing board)
Attach the file here. (forget your 3D sketch for now).
Message 15 of 15
hellolitl
Just installed the SP2 on 2014, 64-bit.
Build: 246 Release: 2014 SP2
Please let me know if you have a solution.
Thanks!
ilya.
