Inventor General
*Expert Elite*
Message 41 of 65 (368 Views)
Re: Posting a project for comments
05-08-2012 07:15 AM in reply to: donovandigital
Extrude your Board sketch 10mm (away from you (-z)).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
*Expert Elite*
Message 42 of 65 (366 Views)
05-08-2012 07:20 AM in reply to: JDMather
Start a new sketch on the XY plane (rather than the part face - always use origin planes when possible).
Sketch a rectangle as shown out in space.
Add circles at both ends from midpoint of horizontal lines out to endpoint.
*Expert Elite*
Message 43 of 65 (362 Views)
05-08-2012 07:27 AM in reply to: JDMather
Add vertical construction line.
Change horizontal lines to construction.
(there is an easier way to do this dragging arcs out from lines, but if you haven't been taught....)
Add a coincident constraint between the midpoint of the vertical centerline to the projected orgin center point.
*Expert Elite*
Message 44 of 65 (361 Views)
05-08-2012 07:29 AM in reply to: JDMather
Dimension the sketch as shown.
 Trim the insides of the arcs.
Then Extrude-Cut through all.
*Expert Elite*
Message 45 of 65 (357 Views)
05-08-2012 07:38 AM in reply to: JDMather
Start the Rectangular Pattern tool and select the slot.
Select the hoizontal line for direction and set to MidPlane.
Set number of copies to 3.
Set distance to 42mm (be sure to change from Spacing to Distance.
It is almost always better to pattern features rather than to pattern sketches.
*Expert Elite*
Message 46 of 65 (354 Views)
05-08-2012 07:43 AM in reply to: JDMather
Start a new part file to create u-bolts.
Sketch a rectangle as shown below the projected origin.
Add a coincident constraint between the top horizontal line and the projected origin.
*Expert Elite*
Message 47 of 65 (354 Views)
05-08-2012 07:45 AM in reply to: JDMather
Add an arc to the top of the rectangle.
Add vertical line from center of arc to top.
Change the lines as shown to construction linetype.
*Expert Elite*
Message 48 of 65 (354 Views)
05-08-2012 07:48 AM in reply to: JDMather
Start a new sketch on the YZ plane (don't create any workplanes that are not needed).
Project Geometry the endpoint of the vertical centerline from sketch1.
Sketch circle at this point diameter 7mm.
*Expert Elite*
Message 49 of 65 (353 Views)
05-08-2012 07:50 AM in reply to: JDMather
Sweep the circle along the u path.
*Expert Elite*
Message 50 of 65 (351 Views)
05-08-2012 07:55 AM in reply to: JDMather
Add the thread features and then the chamers (always do the thread before chamfer to get the correct length).
Save the file as Long U-bolt.
Save As the file Short U-bolt.
The file Short U-bolt should now be the active file.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
