I would like to post my final class project for comments; it contains a bunch of parts files, an assembly, a drawing, and a presentation. I have it in a zipfile, but if you folks prefer I could post in another format.
Many thanks in advance
Joe Stavitsky
I dimension or constrain everything. Geometric constraints are (should be) obvious and take the place of many (most) dimensions.
The dimensions are the dimensions that will be needed out on the shop floor. By fully constraining everything you ensure that the model is not accidently released for manufacture with a missing dimension. (I worked out on the shop floor for 8 years - I can tell you that missing dimensions is a costly problem.)
@donovandigital wrote:Really hope I can build this....
Did you verify the specs on the threads.
As indicated earlier 7mm is an unusual thread.
Re dimensions, that is what I thought.
Re thread
To be honest I don't know how to check this. Can I do this with calipers?
Joe
Measure the diameter of the thread.
Typically it will be slightly undersize. A 7mm thread might measure something like 6.8mm.
Find the pitch by measuring the distance across the crest of 11 threads and divide by 10 (you can just measure the distance from one to the next, but it is sometimes easier to get 10 distances and move the decimal place)
The diameter and pitch should match the list in the aviable Hole Feature.
Yes, use calipers. (there is a special tool to find pitch, but you can do this with calipers as described.).
You could also go to the local hardware store and purchase several nuts of sizes close to what you think you measure. (Be sure to keep them labeled.
You measure the external thread diameter (rod) not the hole.
Will do so this week
But - are all the parts I posted OK?
Thanks again
Joe
