Inventor General
Message 51 of 65 (520 Views)
Re: Posting a project for comments
05-08-2012 07:58 AM in reply to: JDMather
Double click on the thread feature and set to 26mm length (of course do for both).
Edit Sketch1 and change the 50mm to 36mm.
Save the file.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Active Contributor
donovandigital
Message 52 of 65 (513 Views)
05-08-2012 10:34 AM in reply to: JDMather
Why circles and not arcs on the board features?
Thanks again
Joe
Message 53 of 65 (500 Views)
05-08-2012 11:10 AM in reply to: donovandigital
Arcs would be better - trying to avoid any problems (with center point, tangencies...)
The way I would really sketch that is with a line, drag arc, line, drag arc never leaving the line command.  But beginners sometimes have trouble getting a handle on this technique.
And since we aren't even in the same room....
Active Contributor
donovandigital
Message 54 of 65 (494 Views)
05-08-2012 12:12 PM in reply to: JDMather
Insufficient constraints on the hole feature again... sadsad. I haven't tried any constraints yet but what you specified as I'm assuming you found those sufficient.
Will try from scratch with arc.
Also - maybe I misposted, but between the 3 holes there should be 2 raceways for the bearings - width 7mm, depth 7mm. I should do these same way as the holes, right?
Thanks again
Joe
Message 55 of 65 (482 Views)
05-08-2012 01:06 PM in reply to: donovandigital
When you get something like this you have two choices.
1. Keep working at it till you find out why
or
2. attach the file and someone with experience will tell you why within minutes
1 is good, but don't take hours beating your head until you try #2.  Whatever you do, don't ignore and leave unanswered.  Finding the how and why will pay off dividends in the future.
For the bearing slots - do one and then mirror the other. On something this simple there probably isn't any advantage of mirror sketch or mirror feature.
Active Contributor
donovandigital
Message 56 of 65 (478 Views)
05-08-2012 03:32 PM in reply to: donovandigital
Second sketch, fully constrained. For some reason, the lines turned bule but the arcs didn't?
Active Contributor
donovandigital
Message 57 of 65 (471 Views)
another question
05-08-2012 04:05 PM in reply to: donovandigital
Can I change the amount by which I zoom in/out with the mousewheel?
Message 58 of 65 (460 Views)
05-08-2012 05:15 PM in reply to: donovandigital
Forget drawing as arcs - draw as circles and trim as I first instructed.
You have an extra radius dimension (I didn't show to add any radius dimensions).
You are missing tangent constraints between the arcs and the lines.
If I remove the radius dimension and add a tangent constraint - the sketch turns color.
Active Contributor
donovandigital
Message 59 of 65 (455 Views)
05-08-2012 06:17 PM in reply to: JDMather
I can see where missing constraints are a problem, but does absolutely everything need to be dimensioned? For instance, do construction lines need dimensions?
Active Contributor
donovandigital
Message 60 of 65 (445 Views)
05-08-2012 09:58 PM in reply to: donovandigital
Updated board, ubolts, and eyebolt. Let me know if all is up to spec and I will complete.
Really hope I can build this, but I'm worried that some of the detail work is <3mm. A worthy test of my dremel skills at the very least.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
