Inventor General
*Expert Elite*
Message 11 of 65 (515 Views)
Re: Posting a project for comments
05-03-2012 11:30 AM in reply to: JDMather
If you want to take one part at a time and discuss how it should be done - we can do that.
In my experience most students who come here lose interest fast in doing it right, but you did come here for a critique, so maybe you are motivated to learn how it should be done.
Which part would you like to start with?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
*Expert Elite*
Message 12 of 65 (518 Views)
05-03-2012 11:34 AM in reply to: JDMather
Let's start with a nice easy part.
Nut.ipt
Delete the thread feature.
Edit the sketch and add a Vertical constraint to one of the vertical lines.
Notice anything happen?
(the sketch changes color indicating it is fully constrained).
Delete the circle.  Notice anything happen.
Drag the centerpoint of the hex away from and back to the origin center point.
Because Inventor is now confused by the missing circle you might have to re-edit the extrude but simply click OK.
*Expert Elite*
Message 13 of 65 (512 Views)
05-03-2012 11:38 AM in reply to: JDMather
Start a new sketch on one of the faces and Project Geometry one of the hex edges.
Sketch a circle tangent to the edge.
Sketch2.pnge
*Expert Elite*
Message 14 of 65 (512 Views)
05-03-2012 11:39 AM in reply to: JDMather
Extude the circle Through All with the Intersect option and click the More tab and set to 45° to add a turned chamfer to the corners.
Repeat on other side.
*Expert Elite*
Message 15 of 65 (510 Views)
05-03-2012 11:43 AM in reply to: JDMather
Start the Hole command and set to Concentric.
Click the plane and the circle and set to tapped and size.
*Expert Elite*
Message 16 of 65 (509 Views)
05-03-2012 11:46 AM in reply to: JDMather
Add a .25mm chamfer to both sided of the hole.
Change to Chrome texture.
Now isn't that just prettier.  Should make you feel proud!
*Expert Elite*
Message 17 of 65 (508 Views)
05-03-2012 11:47 AM in reply to: JDMather
Which part would you like to do next?
Valued Mentor
GSE_Dan_A
Message 18 of 65 (481 Views)
05-03-2012 12:44 PM in reply to: JDMather
JD is on a roll! GO GET EM JD! :smileyvery-happy:
GSE Consultants Inc.
Windsor, ON. Canada
Mason-Paul
Message 19 of 65 (475 Views)
05-03-2012 12:49 PM in reply to: JDMather
In addition to JD's comments
M7 is NOT a preferred standard metric thread
So it's either M6 tapping hole of 5mm Clearance hole of 6.6mm actual 7mm nerest drill OR M8 tapping  hole of 6.8mm 7mm nearest Clearancehole of  9mm actuall
NOTE
These are UK nearest Tapping hole size they may vary slightly according to different country's standards & drill sizes available.
Inventor 2013 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Mhz CPU , 32 GB Ram
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Active Contributor
donovandigital
Message 20 of 65 (464 Views)
05-03-2012 01:07 PM in reply to: RayFeiler
Many thanks for the correction
Joe
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
